Question about Admiral AW22 Top Load Washer
Mucky water in bottom of washer
Dishwasher fills with mucky water after cycle completed. Dishwasher cleans great.
  • 833 Answers
Sounds like the machine is not pumping out the water at the end of the cycle.  There is a solenoid valve located near the pump down below.  It has a pipe which extends to the waste and another which goes to the wash arms.  The pump will either send water to the arms or the waste.  IF this valve is jammed...usually with food waste...it will not pump out.  Often, the valve can be cleaned and reinstalled.
Posted on Dec 07, 2008
Dishwasher Does not Fill Past First Rinse
There is an anti flood valve on the bottom of the unit. IT could be sticking or have a bad connection. IT should look like a dome shaped housing on the bottom of the tub. If that is not the problem then you are looking at further troubleshooting to see if it is the contoller.
Jan 19, 2014 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
I want to take off the bottom screen to clean debris. I have taken screws out, how do I remove the screen?
You may to remove more screws from around the complete bottom part of your dishwasher. Have you tried to add Dishwasher Magic to clean the grit and grime out first? Or perhaps if you can't find Dishwasher Magic, we started using Tang Orange Juice powder before the days of the modern prodcuts. The citrus in the powder eats all the tiny food particles away.
In either case, empty all the dishes from the inside, add a cup of Tand or follow the instruction on the box of DW Magic. Run your d/w through a complete cycle.
This should clean your dishwasher out.
Hope this solves your problem.
You may contact us at;
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with any questions or comments. Thanks, Ella
Nov 13, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Dec 31, 2007 | Dishwashers
Admiral AW22 Top Load Washer Logo
51 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
