Question about JVC GR-D22U Camcorder
Camcorder screen displays EMG:TUP
My BUSH VCC 200 displays the above message after being used for a couple of minutes.The manual says when this happens you should not use and consult service centre.I only paid about£20 for it on ebay and am reluctant to spend a lot although it has been a good buy until this happened.Is there any way of fixing it or should i just abandon it.|Many thanks
    Sergeant:
    Champion:
  • 330 Answers
Good price but can not use, do you have any idea, how old this camcorder is? this is my experience.
I bought 3 Sony camcorders at different times, I have used not more than 20 times for each one, and my brother bought another kind of camcorder did the same, but after 3-4 years, automatically quit one by one, even my brother’s camcorder quit within 4 years, this is what I think, the big companies like Sony, Jvc etc., won’t let you use the same unit for a long time, from our case, made us thought, they probably put a timer to control the age of the camcorders. Maybe we have to know how to adjust or change the timer chap or it will cost you some money to fix it.
I am still research about this case. And also I have a lot of documents which I can not transfer.
Posted on Jul 01, 2008
Setting the alarm on my KLH200
Try Googling (KLH)(200)(manual) without parens for instructions.
May 22, 2017 | KLH Audio Players & Recorders
When I press the navigation on my new 2015 sonata the screen says to check the sd card, what's happening
This message indicates that there is an issue with the memory card missing or having failed. This card may contain the map files needed to display. You can try removing and re-seating the card to see if the message goes away; otherwise consult your manual or dealer for help.
Mar 06, 2015 | GPS
Tracfone com manual
Contact Tracfone directly to consult with them.
Mark
Motorola Support
Aug 27, 2014 | Motorola Cell Phones
Instructions setting time bush stereo cd clock radio cr608cd
Hold the display mode button until the hours part of the clock flashes on alarm 1. Then press the sleep button twice. This will allow you to adjust the hours part of the time using the CD forward and reverse buttons. To adjust the minutes part of the time hold the display mode button again until the hours part of the clock flashes on alarm 1 . Then press the program button once and the sleep button twice. This will now allow you to change the minutes for your clock also using the CD forward and reverse buttons. Leave for a couple of minutes and your time is now set.
Aug 25, 2013 | Audio Players & Recorders
How to set up bush player to play movies
Read or consult the owner manual which will have hookup and operation instructions.
If do not have that try to Google the model number with "manual" to locate one. You might also try to find and visit the Bush site for this info.
May 29, 2012 | Bush DVD2038 DVD Player
Screen says "locked" and nothing happens when you
The child lock has been enabled on the microwave. To disable the lock, press and hold 0 until the Locked message disappears from the screen. To set the Lock, press Stop/Clear (to clear the display) and then press and hold the 0 pad until the phrase Lock appears and you hear two beeps.
The manual for the microwave is available here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC8130DDS&siteCd=JA_EN_US&userType=Consumer . The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208112P218-60.pdf .
I hope this helps.
May 24, 2011 | Jenn-Air JMC8130DDS Microwave Oven
I have two desk top with similar problems.One is a Dell Dimension2400 and the other is using a N232 MB US using SDRAM memories. Power supply is working but they will not power up. Have change the MB on the...
hummm......did u replaced ur RAM with a standby..??
assuming that u must b a professional as ur disassembling ur pc without any supervision, which may b fatal..!!
and u r using above 512mb/400fsb of ram n of reputed maker (eg Hynix)..
however, proceed with following steps:..
check all the output signal frm the smps..eg. 'pg(violet +5v)', 'sb(if present, grey +5v)' n +3.3(orange) signals r fine..
hv a glance at ur main/mother board for faulty capacitors (esp. above 1000mfd)..the cmos battery above +3v..
if all the above hv been tested by u, see if ur hdd is making any noise (like 'tuk tuk' or 'kirr kirr' or 'sunn')..
replace the ram(s) with standby..
hope it'll solve ur problem..
always better to consult system admin/vendor supervision....
Oct 27, 2009 | Dell Computers & Internet
''stop'' message on electronic programmer - Whirlpool oven
Hi
all you need to do is set clock as oven is in auto mode
to do this you need to press the middle button a couple of times
hope this helps
Mar 19, 2009 | Ovens
ROS Trouble with Xerox DouPrint N17
The ROS is the laser. Believe me you can replace the machine for less than the cost of a laser. The Polygon motor is most likely bad in the laser. I would guess in the $500 range for the laser
Dec 09, 2008 | Xerox DocuPrint N17 Laser Printer
200 ARC
Try and use it in 'safe mode' by pressing F8 in advanced startup options.
Then do the system restore.
Sorry if it dosen't help but i can't really reply in fully on a forum.
Jun 29, 2008 | Computers & Internet
JVC GR-D22U Camcorder Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
