Question about Systemax Computers & Internet
SYSTEMAX HARD DRIVE INSTALL SHUTS COMPUTER DOWN
I TRIED A 40 GB HD AND A 160 GB HD/ SAME RESULTS.
COMPUTER SHUT OFF. TRIED AN OLD HD 1993 MAYBE
NO SHUT DOWN BUT NO STORAGE SPACE FOR WINDOWS OS.
PLEASE HELP/ ANGIECECELIA
Sunil Panem
  • 80 Answers
SOURCE: help my second hard drive dont show up
Hi
Make sure it is connected properly.
Then go to Disk Management by typing "diskmgmt.msc" in the Run window.
Then check in Disk Management if there is any unassigned or any uninitialised partition there.
If you find one, right click on it and then select either "Format" or "Initialise".
Posted on Mar 05, 2008
SOURCE: computer shutting down
this is mostlikly due to a virus or the computer is overheating and shutting down to avoid buring something up
Posted on Jun 27, 2008
frcs68
  • 1605 Answers
SOURCE: I PLUG IN A BRAND NEW WESTINGH. HARD DRIVER 160 GB AND COMPUTER S
did you configure the 160GB hard drive as second???
there is a shorting pin between the ribbem cable and the power cable.
take a look on the hard drive, there should have adiagram shows where the shorting pin need to go to make it as secondary drive.
install the hard drive as secondary drive.
if you want the drive to be the primary. you nee to install the operating system on it.
with out operating system the machine will boot up in to DOS only, and a error message telling you the drive has no loader.
Posted on Nov 12, 2008
rylee_smith
  • 8619 Answers
SOURCE: Compaq Presario sr1000(sr1430NX) will not stay powered on
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Posted on Feb 11, 2009
Geekman
  • 32281 Answers
SOURCE: I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Posted on Aug 27, 2009
A friend of mine sent me a Western Digital WD1600BB 160 GB hard drive to replace my ole 80 GB one. It is a completely blank drive, I installed it using the Master plug, booted the computer from the CD...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 24, 2011 | Western Digital Caviar WD1600BB 160 GB...
HD/MOTHERBOARD ISSUE
You can try using FDISK to partition the drive into multiple smaller drive images.
Sep 13, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
New hard drive reloading oc
Hi Amy,
It really depends if the notebook is capable of supporting 160 gb HDD or not.
It case it is cabable call Hp and order anew set of Recovery Cd and it would work fine.
Apr 27, 2009 | HP (PV944A) 160 GB Hard Drive
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Hd power problem systemax cpu
If you would provide more information about your Systemax system... model/serial number I can look the specs up. I can tell you the only way that it could be the hard drive would be if you had a bad power supply, not that your system can't handle the "power" of the hard drive. If you end up getting a new power supply, you could opt for one with a little higher wattage if you'd like. A 160gb hard drive isn't going to pull any more meaningful amount of current than a 40gb. What I would look at would be wither you had the jumpers on the hard drive configured correctly. For info on jumpers, see...
http://en.wikipedia.org/wiki/Jumper_(computing)
Individual drive manufactures and drive models have different method for setting the jumpers and it will also very on what other IDE connected devices you have in your computer (optical drives, hard drives, Zip drives, and etc.).
Nov 25, 2008 | Dell Inspiron 2200 Notebook
Nov 12, 2008 | Dell Inspiron 2200 Notebook
Trying to install new Ultra-ATA hard drive on my six year old SysteMax Tiger PC.My BIOS recognizes the hard drive,but Windows XP will not install for some reason.I've been told to re-install the...
update your system bios first. as far as parition magic's related error.. if you were you delete the parition and recreate it, you should be ok. What's the error message you receive when you try to install windows on it?
Jun 17, 2008 | Systemax Computers & Internet
New hard drive 160 GB ATA can't be partitioned
why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
Feb 26, 2008 | Computers & Internet
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
WD - My Book Won't shut off with computer, and now can't locate
Try unplugging Hard Drive, then a reboot of your pc and when the pc comes back plug it and then Power it ON. Hope this Helps Mutahir
Feb 03, 2007 | Western Digital My Book (WDG1U2500)...
Computers & Internet Logo
35 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
