Question about Inland 58016 Wavetable PCI Sound Card
Actually I already tried that
I used the default settings, and when I click "install" I get an error message reading "Setup has caused an error in SETUP.EXE. Setup will now close." I'm at a loss.
  • 47 Answers
Ok Joe, Just to make sure we're on the same page here, are you using winzip to unzip the files? If so when you double click setup.exe do you get a dialog saying "Winzip will extract all files to a temp folder and run the setup.exe program"? If not I want you to try opening the .zip and hitting the "Install" button. If that does not work we could try an end around on the setup. First unzip those files into a new folder that you know where the folder is, we're going to need it later. Go into device manager (it's been a while since i've used ME but it should be under Control Panel, System, Device Manager tab) Find your sound card, right click on it and click "uninstall". Now reboot. Windows should see the card again and try to reinstall it. When it does hit "Have Disk" and hit "Browse" then goto the folder you created when you unzipped the files. Hit "Ok" That way will not install all of the "extras" you might get from running the setup.exe but it _should_ allow windows to use the sound card. Lemme know how it goes, Dude
Posted on Nov 16, 2006
    President:
  • 2,961 Answers
Try another way around,right click your sound card in device manager and click update driver; forcing it to look wherever you have the setup.exe stored on your pc, the file you are using is probably not a manual setup, but has the required .ini or .dll file required for your card.
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
Windows security center
If this is your router and you've forgotten the username or password we suggest that the router be reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Sometimes when attempting to visit a secure website on your Windows computer, you will receive a message about a security certificate error.
You will have the option of whether to continue to the site.
Secure websites, such as an online bank or retail store, use security certificates so your browser knows that any financial or personal information you enter on the website will go the correct place securely.
Every error message does not necessarily indicate a security problem on the website.
Check your computer's date and time.
If they are incorrect, you will receive security certificate errors.
Click on the time in your taskbar, and set the correct time in the pop-up window.
Refresh the website where you received the error message.
If you receive a security certificate error message again, the problem lies with the website's security certificate.
Click the icon that looks like a padlock next to your browser's address bar.
Read the information in the window.
This will detail who owns the website, the site's verification status and any known information about the website's trustworthiness.
Compare this to what you know about the site you were attempting to visit.
Click "View Certificates, then "Install Certificates."
Click "Yes" at the security warning to install the certificate for the website.
May 20, 2013 | Linksys WRT Computers & Internet
How do you fix the internet explorer
You do not say which version of Windows you are using or the version of Internet Explorer so here is a general idea to fix.
If you are running XP or Vista download the new version IE8 and install it. Here is the link:
http://www.microsoft.com/windows/internet-explorer/default.aspx
Mar 25, 2009 | Microsoft Windows XP Home Edition
Hardisk not detect.
First Make sure the hard drive power connector and ribbon cable are connected.
Swap the hard drive.
if id doesnt wrk then..
Go to the BIOS setup, and under the Integrated Peripherals menu, make sure that ‘On Board HDC’ is enabled for both Primary and Secondary channels. Also ensure that all drive types are set to AUTO under the Standard CMOS Setting. If you are not comfortable with changing the BIOS values, just reset the BIOS to factory defaults.
Hope this helps
keep me updated
Thanks for using Fixya
Have a nice day!
Mar 06, 2009 | Computers & Internet
Bios checksum error. How to solve it?
If you are using an old computer, there’s a possibility that you already encountered this error message during bootup; “CMOS checksum error – Defaults loaded”. At this point, the PC will halt its operation and requires you to press F1 to continue or DEL to enter setup (mostly but also depends on motherboard) to proceed.
This is caused by incorrect or corrupted CMOS values. BIOS settings are stored in CMOS. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, the error message will be displayed.
For most cases, this is caused by the motherboard battery. Buy a new one to any electronic retailers in your area and replace it. Turn on your computer and press the stated key to enter the BIOS setup. It can be DEL for some or F2 but this depends on your computer. On the BIOS menu, try to change the DATE and TIME settings because their values are reset to different value. Most settings are set to default so leave it as it is. Save the settings and reboot your computer.
Oct 04, 2008 | MSI PM8M-V Motherboard
Microsoft office
When you try to start a Microsoft Office 2007 or Microsoft Office 2003 program, you may receive the following error message or an error message that is similar to the following:
Error 25090. Office Setup encountered a problem with the Office Source Engine, system error: -2147023836. Please open SETUP.CHM and look for "Office Source Engine" for information on how to resolve this problem.
CAUSE
This behavior occurs when the following conditions are true:
* Two people installed Office on the same computer.
* Both installations were completed by using the AllUsers="" parameter to set the installation for the installing user account only.
* When both people were prompted to remove files that were copied locally at the end of Setup, both people did not remove the files.
* One of the two people removed Office.
RESOLUTION
To resolve this behavior, start the Setup program for Office. To do this, follow these steps:
1. Insert the Microsoft Office 2003 CD in your CD drive or DVD drive.
2. If the Setup program does not start automatically, locate the Setup.exe file on the CD, and then double-click the file to start Setup.
3. After the Setup window appears, cancel Setup, and then respond to the prompts to exit Setup.
Note: You do not have to complete the Setup program. Setup fixes the error condition when it is first invoked.
Sep 05, 2008 | Microsoft Office Outlook 2003 for PC
Printer staus unavailable at this time
A couple things I would check that can cause this, all related to PC to Printer communication.
  1. Cable problem: Printing locally with a non-bidirectional printer cable from LPT1.
  2. Configuration Issue: Printing via IP and having designated in the device setup more trays then actually exist. For example, checking that you have a feeder when you have only the default tray.
  3. Resource Conflict: Printing via IP when another device is using the same IP.
  4. User Error: Having multiple copies of the same printer. i.e. 8500DN, and 8500DN(1) setting one up but having the other set as default.
Jul 24, 2008 | Xerox Phaser 8500/DN Printer
"File not found" error message when I try to use a saved network settings file to
CAUSE This issue may occur if you change the file name from the default file name "Networksettings.xml". RESOLUTION To resolve this issue, do not click My settings are on a floppy on the Where are your network settings located? page in the Microsoft Broadband Networking Setup Wizard. Instead, click My settings are in a file available from this computer, locate the floppy disk drive, and then click your configuration file.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
"File not found" error message when I try to use a saved network settings file to configure my Microsoft Broadband Networking hardware
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Inland 58016 Wavetable PCI Sound Card Logo
179 people viewed this question
Top Inland Computers & Internet Experts
Norm Doty
Norm Doty
Level 1 Expert
Jeff richtman
Jeff richtman
mypoohbear25
Level 1 Expert
Are you an Inland Computer and Internet Expert? Answer questions, earn points and help others
