Question about SanDisk Sansa e250 MP3 Player
HELP how do i get rid of the refresh database screen and restart my mp3
  • 8,596 Answers
Reformat the player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
My mp3 player keeps freezing on "refresh database"
Turn on and allow to run dead.Fully recharge then .restart should be fine.RICHARDM69
Jan 02, 2009 | SanDisk Sansa e200 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e280 goes to glitch screen after trying to refresh database
if the bar in the middle of the window has stripes its normal and it will keep doing it no-mater wat you do
Oct 26, 2008 | SanDisk Sansa E280 MP3 Player
Sana e280 frozen screen reads Refresh Database
put the player in recovery mode by placing the hold slide button at the top of the player so that the red showes, held down the record button while turning on the player. upon connecting the USB cable the unit will go into the recover mode. Go to my computer and look for the drive which states "16MB Format" and copy the firmware files into it. Disconecting the cable after the files are copied will cause the player to reload the firmware. The player will restart and then shut off because of the Hold button position. Slide the Hold button back into normal mode and push the menu button to restart. The unit will power up and display the language settings. I went to the settings menu and changed the player USB setting to USC. I then placed the player in recovery mode again and went to the MY Computer again and set window to show hidden files. This allowes windows to see the database drive. I then ran chkdsk on the database drive which found a lot of crossed linked files. This then allowed me to delete all the files in the database. Upon comming out of the recovery mode the unit restarted normaly.
You can get the firmware at this site. http://mp3support.sandisk.com/firmware/e200/e200v101.02.18a.zip
Oct 11, 2008 | SanDisk Sansa E280 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database message
Check out solution 4 here:
http://www.fixya.com/support/t131894-format_sansa_e250
Several people have said that it didn't work for them but it has worked 100% for me. I've bought about 10 problem Sansas from Ebay and fixed them all at (least 6) with this problem.
Feb 27, 2008 | SanDisk Sansa e250 MP3 Player
Refresh Database
Reset the player first - that should get rid of the message. Is your mp3 player a Sansa player, or an Apple iPod - both of them have a recovery method which you can find on their respective websites. I'm too lazy to paste the instructions again.
-Tha Mp3 Doctor
Feb 02, 2008 | SanDisk Sansa c200 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Frozen in refresh database
download some firmwire from http://sandisk.com/Retail/Default.aspx?CatID=1376
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
