Question about Bushnell NorthStar 78-8846 (675 x 114mm) Telescope
Inverted image Hello, when looking thru the lens of my 78-8846, land based images are upsidedown. Is this normal, or has something not been put together properly. Thanks
  • 3,186 Answers
All images in astronomical telescopes are upside down and reversed-- this is normal. There is no up or down in space. Reversing the image just adds more GLASS to the light path.
Posted on Dec 28, 2008
Everything revolves around a buck. Kiss mine.
Posted on Nov 15, 2008
Back up camera image has reversed, how do I correct it
Inverted image on back up camera - JK-Forum
www.jk-forum.com/.../jk.../inverted-image-back-up-camera-245590/
Aug 26, 2012 - One was a normal image, which was for front or side cameras. The other is a reverse or mirror image, which makes the backup camera look like ...
backup camera image flipped - Nissan 370Z Forum
www.the370z.com > Tech Area > Audio & Video
Jun 10, 2012 - 15 posts - ‎7 authors
With some of the camera there is a connection that is either made or broke to reversethe image. I would check the connections near the ...
Nov 01, 2015 | Cars & Trucks
When I look through the view finder--everything is upside down???
Astro telescopes normally do show an inverted image, since for most purposes this does not matter. For terrestrial viewing, such as thru someone's window, you can buy an "erect image" or "correct image" prism which gives an upright image.
http://www.optcorp.com/telescope-accessories/optical-tube-accessories/diagonal-prism-eyepiece-holder.html?a_diagonal_design_f=1090
I don't know of such a thing for the finder scope, you would have to buy a new finder.
http://www.optcorp.com/celestron-9x50-illum-ra-correct-image-finderscope-93781.html
Mar 06, 2014 | Celestron NexStar 114GT (269 x 114mm)...
Image showing upside down
It is normal for astro telescopes to show an inverted image. It may seem odd but this is the case. It does not matter when viewing stars, but occasionally it is a problem eg for lunar viewing.
Therefore, and for land "terrestrial" viewing, you can fit in an "erecting" or "correct-image" prism
http://www.optcorp.com/open-box-orion-45-correct-image-prism-diagonal-1-25inch-07216-7037.html
There are many brands, some more expensive, for photography
http://www.optcorp.com/ba-amici-2-2inch-90-erecting-prism-star-diagonal.html
Nov 28, 2013 | Celestron AstroMaster LT 76AZ Telescope...
Hello, I m using the 60700 Telescope but the image i see in lens is very blurred, i assembled my telescope as per Manuel instruction but still i see upside down image with blurred effects. I tried several...
All astronomical telescopes show upside down and or inverted images-- it's normal nothing is wrong. You are applying too much magnification. Do not use the 2x barlow-- and start practicing how to focus using only the eyepiece with the largest number written on it which is your LOWEST power.
You can practice focusing during the daytime on a distant object like a telephone pole or a building.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Jul 29, 2011 | C-Star Optics 60700 (60x700) Telescope
My webcam shows everything upsidedown, I also cannot find the webcam icon to try and fix it.
Hi cutebutevil3,
Based on your situation. I suggest trying the following steps:
The image in your Webcam Uploader window might be inverted because of your camera setting.
To change the setting:
1. Click Messenger and select "My Webcam."
2. In the window that opens, click the "File" menu, select "Preferences," and choose "Webcam".
3. Click the "Camera Settings" button.
4. There is usually a checkbox for "Invert Image" or "Mirror Vertical." Un-check this box if one exists. If you can't find this checkbox, try searching the other tabs.
For yahoo messenger
1. Log on to yahoo messenger then go in preferrence.
2. Then webcam select webcam setting & then deselect the IMAGE FLIP.
3. Now save the setting.
Hope it helps.
Thanks for using FixYa
Best regards,
Jem07
Dec 24, 2010 | Lenovo IdeaPad Y510 Notebook
Is inverted image normal
Most astronomical telescope show upside down images-- no problem as up or down do not exist in space!
You can buy an "erecting" diagonal for terrestrial use.
http://www.telescope.com/control/product/~category_id=diagonals/~pcategory=accessories/~product_id=08787
May 15, 2009 | Tasco Galaxsee 45-060675 Telescope
Just bought a cheap, used Tasco telescope. Images
I'm not sure what type of telescope this is (refractor, reflector, etc.) but it's normal for most telescopes to have inverted images. There is no up or down in space so it doesn't really matter when you view an astronomical object. You just want to keep that in mind if you use a moon map so that you can get the correct orientation. However, you can get moon maps with inverted images.
If you wish to view land or terrestrial objects you can purchase an image erecting prism to turn everything right side up. Depending on the telescope it may reverse the images from left to right when it does this.
I hope this helps.
-jodair
Mar 28, 2009 | Tasco Optics
THINGS UPSIDEDOWN
It's the nature of the way telescopes work that means all images are seen inverted. For astronomical use, this isn't really a problem.
You can buy an "image erector lens" to correct the image and see it rightside-up though.
Dec 29, 2008 | National Geographic 76AZ (525 x 76mm)...
Inverted Image
Page 101 of the manual shows an inverse colour option. Have you accidentally set this to on? Or it it a mirror image that you describe?
Apr 18, 2008 | Nikon Coolpix 5400 Digital Camera
Bushnel North Star
No you do not have anything wrong. When ever light is passed through a lens it is inverted. Binoculars, and land viewing telescopes use a special lens combination or "erecting" prism to flip the image for you. The problem with that is it reduces the amount of light that passes through the telescope. It's not an issue for land viewing because these things tend to be close and bright. For astronomy objects are so faint that you actually get a better view when things are upside down.
Sep 24, 2007 | Optics
Open Questions:
Bushnell NorthStar 78-8846 (675 x 114mm) Telescope Logo
412 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
