Question about Garmin GPS
Why am I not given the option of downloading maps for all of North America (Canada & U.S.)? Only options were Canada and Border States, lower 48 States, East & West. I initially downloaded Canada and Border States but didn't have access to southern States. I then downloaded lower 48 States and now don't have Canadian maps. Please provide assistance as to how to obtain maps of ALL of NORTH AMERICA. Thanks, Gerry Ginter
5 Suggested Answers
SOURCE: Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Posted on Mar 04, 2008
SOURCE: My Garmin nuvi 350, North America, will not show picture.
don't know I to use the garmin 350
Posted on May 05, 2008
SOURCE: How do I unlock the Canada maps?
I had same problem, purchase Sd card, because internal memory too low for all Canada and Usa. search thepiratesbay.org for unlocker program. It works like a charm. Ps i dont know the legality of using unlocker so you may want to consult Garmin.
Posted on Jul 28, 2008
  • 36 Answers
SOURCE: unable to find/use Canada Map on TomTom ONE 125
Nowadays TomTom provides all of its maps through TomTom Home desktop software.
You have to download and install that, and then connect you TomTom to your computer. Then you can browse through and purchase any of the available maps through the software providing you have room on your TomTom to hold the map.
Posted on Aug 02, 2009
  • 504 Answers
SOURCE: Garmin will not recognize destination
How are you entering it? You should go to "Where to?", "Address", then "Spell State/Province". Enter "On" and the unit should pull up "Ontario". Press this, then press "Spell City/Postal Code". Type "Ot" and the unit should pull up several cities, including "Ottawa, ON" Press this, then enter the rest of the address. Let me know if this helps.
Posted on May 09, 2010
Only shows us routes not canada
I fell foul of that the other way. I have Canada maps and lent it to a friend who was going to California.
You need a map that covers Canada and it is an extra cost. The USA is in two zones, or one map does both zones.
You need to buy the Canada maps and then put it on an SD card. The map costs $84
https://buy.garmin.com/en-CA/CA/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt-canada-only/prod8750.html
City Navigator North America NT Canada Only Garmin
Feb 20, 2016 | Garmin Nuvi 2360Lmt - Gps Receiver
Can a New York card be used in Florida ?
Depends on the make and model. Garmon splits the US up. The chop of California for some reason.
City Navigator North America NT Lower 49 States Garmin
This one does all of North America, so check your maker.
https://buy.garmin.com/en-US/US/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt/prod1456.html
Dec 02, 2015 | GPS
Why when I try to enter an Address with State = California, my Garmin Nuvi 660 only shows "Cayman Brac" and "Connecticut"? I'm on software version 4.90 and I have "CN North America NT 2015.40 ([1] Lower...
CN North America NT 2015.40 ([1] Lower 49 States NE)
NE = NORTH EAST... California is not in the North East of the United states. This device only has a small internal memory so you need to use a 4 GB memory card and load maps to that card with MapInstall:
How do install mapping to my device with MapInstall
Mar 24, 2015 | Garmin Nuvi 660 GPS Receiver
I updated my garmin nuvi255 and it only shows usa maps, now I lost all of Canada
When you update the unit you are given selections based upon how much memory is available on your unit. With each map release, the map sizes become larger. On the 2xx series, you may not have had enough memory to have both the US and Canada map, so it probably only installed the lower 48 states. You will need to install the map on an SD card in order to have both maps on the unit.
Sep 06, 2013 | Garmin nuvi 255W GPS Receiver
I want to register my product on-line but cannot get past www.danby.com
click on "Product registration" then click on the map of "North America" or select from the options (Canada - English, Canada - French, US - English) where you are and you should get the registration page
good luck
Aug 24, 2011 | Refrigerators
How can I put in an address for Canada from Michigan? It only lets me put in States.
The 330 model cannot hold all the maps for canada and the lower 48. Using mapsource, you can load the lower 48 only or Canada plus the northern states that touch Canada which you should do do get from Michigan the the great white north
Dec 07, 2009 | Garmin StreetPilot C330 GPS Receiver
Jul 26, 2008 | Garmin nuvi 200W GPS
(Untried)
Must have:
2 - 512mb SD card
What to DO:
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
