Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome 9000 willl not work when turned on
My wife's janome 9000 has this message when turned on "Raise pressure foot and needle bar,and then turn back on" she does this the machine will not work and continues to give her this message. She says she has checked the knee lift. It is an intermitten problem she took in for service and they could find nothing wrong. Thank You for any help
  • 2 more comments
  • Anonymous Mar 15, 2014
    I tried to sew on my Janome memory craft 10000 but it prompt me to raise pressure foot n needle bar, then turn power on again. I hv tried many times but it does work and keep on prompting the same message on the screen. I can't start sewing at all. What's wrong? Pls help.
    I tried to sew on my Janome memory craft 10000 but it prompt me to raise pressure foot and needle bar, then turn power on again. I have tried many times but the message keep appearing on the screen. Now I still can't start to sew. What's wrong with the machine and what I need to do? Pls help.
    I tried to use my Janome memory craft 1000 but it prompt me to raise pressure foot and needle bar, then turn power on again. I tried many times but it still can't work. The message keeps appearing on the screen. Now I can't even start to use the machine. What went wrong? Pls help.
  • Anonymous Mar 19, 2014
    When I turn my Janome MC10000 on, it comes up with a msg to lift presser foot and raise needle then turn off and on again - error #08
    Nothing will get it to turn on without this msg and of course it will not sew. Thanks
My Janome 9000 has always done that. I can prevent it by raising the needle when I first start the machine, getting it to sew quickly or raising the needle and letting the machine sit for a few minutes. I think my computer wants to warm up a minute. As you can see I.m not a technical person but it works for me.
Posted on Jan 08, 2008
SOURCE:
When I turn my Janome mc 9000 the screen says raise presser foot and needle bar and switch it off and back on. I did this several times and it still says same thing.
Almost defiantly a sensor issue. These are not easy machines to work on due to their hi-tech design. Clean and inspect as much of the mechanism as you can as some cotton or fluff may be obstructing a sensor or switch. This may stop the machine from calibrating.
Below is a link to a PDF of janome error diagnosis. It is a bit complicated but one of these steps may solve your issue or offer a solution.
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj1mtPo-fLNAhXqDMAKHfgCBYAQFgglMAA&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
Jul 14, 2016 | Janome Memory Craft 9000 Computerized...
Error message #2
Perhaps this error list will help you resolve the problem:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwijuKaq-9fJAhUD6WMKHXLVCyYQFggjMAE&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
Try lowering the pressure foot and the needle and then raise them
again and then restart the machine, and if that doesn't clear the
error message then it's time to service the machine.
Dec 12, 2015 | Janome Memory Craft Clothsetter 10000
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Janome 9700 suddenly is showing warning. Raise
Ask the seller! He has a vested interest in helping your machine work! As a former newspaper writer, believe me, if you send something to a local rag, about your problems with your Janome, the seller will sit up, and take Notice!
Oct 23, 2013 | Janome Memorycraft 9700 Computerized...
Janome 9000
Did you raise the presser foot and needle?
Oct 11, 2013 | Sewing Machines
My sewing machine model no 9000 is showing a error is '' raise the pressure foot and needle bar then power on #01
First, I would make sure the embroidery unit is unplugged if you r trying to sew and check the bobbin winder to make sure it is off. Also look for thread in the guide, these machines are very sensitive and when the slightest bit of thread gets caught in the tension of the threading format, the computer will automatically turn on error message.
Sep 16, 2010 | Janome Memory Craft 9000 Computerized...
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
Says raise pressure foot and needle bar
check youre screen you will see an icon of needle you have got it in the down mode touch it it will raise it next time you sew it will be raised this is an option to have needle in fabric or raised on completion of sewing this is in your manual.
hope this helps mary h
Dec 18, 2008 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
504 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
