Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore refrigerator door will not close completely
The door on my Kenmore refrigerator will not close completely. I have remove anything that might be blocking it. But do not see any anyway to adjust the door hinges. can you help me? TC
  • Anonymous Feb 08, 2009
    The top door is not closing completely and seems to need to be adjusted. How can I do that?
Both top and bottom doors will not close on mine
Posted on Feb 19, 2009
We have a 2011 Kenmore refrigerator. We have had Sears come out 2012 and 2013 and they say there is nothing that can be done for all the frost that keeps showing up in the freezer part. We have wiped it...
Frost is caused by an air leak. Door doesn't fit, gasket mis-shaped, ice chute door not closing completely. Adjust the door; use a hair dryer to heat the gasket to have it return to its original shape; put the gasket back in it's track; replace the solenoid that closes the ice dispenser door.
May 31, 2017 | Kenmore Refrigerators
KITCHENAID SIDE BY SIDE REFRIGERATOR FREEZER DOES NOT FREEZE LIKE IT SHOULD BE. STILL WILL MAKE FEW ICE FROM THE ICEMAKER BUT DOES NOT FREEZE LIKE IT SHOULD BE, REFRIGERATOR IS AT ITS MAX TEMPERATURE WHEN...
Clean condenser coils, remove anything around refrigerator that might prevent air flow on coils. Make sure freezer and fresh food area door are completely closed.
Aug 01, 2017 | Kenmore Side by Side Refrigerator
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
I bought a kenmore refrigerator model 71303... a french door model with nothing on the doors (dispenser-wise) and a pull out drawer freezer. fits the space in my kitchen perfectly, however I just...
Unfortunately, 71303 is not a complete model number, even though that is how Sears lists the unit here: http://www.searsoutlet.com/22-7-cu-ft-French-Door-Bottom-Freezer-Refrigerator/d/product_details.jsp?pid=41106&mode=seeAll . However, most french door refrigerators can have the doors and freezer drawer removed. I think your model number will be 795.71303* (there are a few digits omitted). The manual is available here: http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1103856L.pdf . The directions for removing the doors and freezer drawer start on page 11 (page 10 of the PDF).
The 795.71313 is a similar refrigerator. The directions to remove and replace the doors and freezer drawer is given starting on page 13 in the manual. See that manual here: http://c.shld.net/assets/docs/spin_prod_946454012.pdf .
I hope this helps.
(Kenmore refrigerators are made by other manufacturers. The three digit prefix in the model number is important to find the correct manual. A different French door refrigerator, 106.7200*, can have the doors removed. However, only the front of the freezer door comes off. That manual is here, http://c.shld.net/assets/own/spin_prod_734629012.pdf; see page 10 and subsequent pages.)
Mar 12, 2017 | Kenmore Refrigerators
My door does not close completed.sometimes when you close the freezer the air pushes the borrom door open
Raise the front legs to where they are slightly higher than the rear; that throws the weight of the doors towards the rear of the icebox.
Jan 19, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a Kenmore model#1069557915 S#SG1047043 03/97 Coldspot Just recently the main door doesn't completely close, any recommendations?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 17, 2009 | Refrigerators
Repair icemaker shoot on door
icemaker shoot on door keeps freezing up nd does not let the ice cus or the crushed ice go thru.Help!
Sep 03, 2008 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
912 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
