Question about Magic Chef CYE4000AWW Electric Dryer
No circulating heat
The dryer heats up and the drum spins it just won't circulate or bloe any heat.
    Scholar:
  • 157 Answers
Hello mojack448, check the vent, its plugged ether in the lint catch filter or the exchaust duck work. Merry Christmas.
Posted on Dec 05, 2008
Hoover DYC9913AX
gentlmen you need to move with the times this tumble dryer has no element it is whats caled a heatpump solution ,there is no exhaust for the air to go out of as it is a sealed enviroment the air re-circulates within the machine
Nov 07, 2012 | Hoover Dryers
Samsung dv218eb dryer runs but won't heat
No heat almost always means a heating element. But if you ar talking low heat, then check the lint filter; exhaust pipe for clogges and that the fan is circulating the heat up to the drum.
Aug 14, 2011 | Samsung Dryers
The drum circulates, but there is no heat. I've reset the breakers and freed up the vent. Still no heat.
Heating element or thermostat - NTC defective. It could be a broken wire but i doubt it. Check the heater first for continuity then the thermostats if there is one... NTC controls need a service routine to check. Good luck....you might need a technician I think. Cheers
Feb 27, 2011 | Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
I need to figure out how to get the front panel ff of my daughter's kenmore dryer Mod #96093800 to clean the lint from inside. Also the dyer heats up but doesn't get hot. any suggestions
First you have to remove the back and then top of the dryer, then you will have to remove the drum. After the drum is removed you may see screws along both sides on the inner corners of the front. (You may not have to remove the front once drum is out.) Remove these and the front should come off. There is usually lint jammed in the front tube if this dryer has a lint trap under the door, thus causing the heat not to circulate through the dryer.
Feb 21, 2010 | Kenmore Dryers
The dryer heats, the drum turms, hot air circulates, but the clothes don't dry
If you are experiencing longer dry times and poor drying efficiency, the following link can give you some advice on things to check before assuming you have a malfunction with the dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If the dryer can't exhaust properly, the moisture is retained in the dryer drum and your clothes stay wet, longer. A dryer in a clogged or poorply ventilated state can also cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please post back and let me know. I hope this helps you.
Dec 29, 2009 | Roper RES7646KQ Electric Dryer
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
No heat
it happens to me too in a different dryer when it goes off it does click click click click fast
May 21, 2008 | Whirlpool Dryers
Magic Chef CYE4000AWW Electric Dryer Logo
53 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
