Question about Bosch Dishwashers
2 years old but NEVER used it yet. Put on today and it would not run any cycles. Let in water and emptied it out but would not do a wash cycle. All this from start to finish in about 8 mins. Washer kept making this droning noise as if it was trying to do something but couldn't. Checked all the waste pipes and filters - all clean - By the way it was still empty of crockery when I tried to do this. Bosch Model SHV55 MO3GB
  • 22 Answers
Dishwasher have a antiflood device system in the base of the applince try a tip the machine backwoord or sideway if water comes out the base you have a leak generally associate wit a failure of the seal around the impeller of the motor or the microswitch of the antifllod is stuck. to check remuve lid remuve left side panel two torke screw size 17 or 20 and unclip look inside ther is a red stick that operates a little round polistaring float ( antiflood device)
Posted on Nov 13, 2008
How do I fix my washing machine? It doesn't appear to feed enough water into the machine. The machine runs through a full cycle but appears low on water even in the middle of a full wash cycle.
I can try to explain the difference between today and the old washing machine. My question would be, are you satisfied with the washing result? If so, then everything is fine.
There are four factors that affect the washing and they make one single round (duration, temperature, mechanical action, chemical action). Old washing machines are spending more water, more detergents, more electricity power, and consequently more spoiled environment and duration of washing was app. from 1 to 1.5 hours. Today washers use less water, less detergent, less energy power, less polluting but because longer duration of washing cycle app. from 2 to 3 hours, wash result was the same as in the old machine.
I think that today confuses people how is possible that washing machine wash three hours (longer than before) and consumes less energy? Believe me this is true, and every service tehnician will explain it.
Because old habits many customers put the same amount of detergent (do not read the manufacturer's instructions) and therefore have problems with the skin. That is why an increasing number of washing machine has the option of additional rinsing cycles.
Dado
Jul 23, 2015 | Bosch Washing Machines
Why doesnt the fabric conditioner dispenser empty after each wash?
The softener dispenser is flushed with water as part of the wash cycle. The residual water prevents softener from clogging the dispenser between was cycles.
Aug 01, 2014 | Hotpoint Washing Machines
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
I need to get rid of hard water scales inside the dishwasher
One of the safest and least expensive ways to remove scale is to run the EMPTY dishwasher through a cycle using 1/2 cup of white vinegar. If all the scale is not removed during one cycle, then repeat the process.
I hope this gets rid of your problem. If it does, please come back to fixya and rate my solution!
Jun 29, 2011 | Dishwashers
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
2 yr old Whirlpool duet washer,suds and now f35 codes. Also when put on cold water i can only get hot water ?
the only reason you would get hot water on the cold setting is if the water lines have been crossed.you can usually clear the cosde by running nothing but clean water through the wash cycle and then use a little less soap.on the next was cycle.unplug the unit for a little bit then wait awhile and run the washer empty.
Nov 17, 2010 | Whirlpool Washing Machines
Washer won't drain
I don't know how it was fixed. I kept on running it through cycles and the water finally drained.
Dec 05, 2008 | Kenmore Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Runs full wash cycle, but there it is still full of water and suds
Amy, there was a service flash for the lid switch on this model. The contacts inside the switch were sporatic which caused; stopping in mid cycle, wet clothes and no drain. You would have to put it in spin and have someone jiggle the wires to the lid switch to verify that this is the problem and not a timer problem. I really think it's a lid switch problem. Your part number for the new, non adjustable switch is 12001908.
Jan 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machine won't empty water during the cycle
does the timer advance by itself? if not the problem is your timer not advancing through the cycles. if timer does advance then being 14 1/2 years old it could be the motor. start the washer and mark the beggining where the timer starts. whatch it to see if it moves if not then you need to replace your timer
Jan 30, 2007 | Whirlpool LSR9434PT Top Load Washer
Dishwashers Logo
224 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
