Question about Dell Dimension 2400 PC Desktop
OBD steps Can you tell me all the different steps of the process that starts the On-Board Diagnostic on recent desktop systems? ~Thanks
    New Friend:
  • 4 Answers
Not Beep Codes
Posted on Feb 26, 2013
  • Dell Master
  • 4,806 Answers
Operating system or hardware diagnosics?
Posted on Nov 13, 2008
Park ave 2000 odometer and prndl not visible resodered the resistors no improvement noted
Did you perform the Instrument Cluster Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Instrument Cluster
Turn OFF the ignition.
Install a scan tool.
Start the engine.
Place the gear shift lever in the following gears:
• PARK
• REVERSE
• NEUTRAL
• DRIVE
Observe the Transmission Range parameter in the powertrain control module (PCM) data display.
Does the scan tool indicate that the Transmission Range parameter is the same as the PRNDL display for all gears?
YES - Go to Powertrain On Board Diagnostic (OBD) System Check Engine Controls - 3.8L
NO - Go to Step 3
Replace the instrument cluster. Refer to Instrument Cluster Replacement .
Did you complete the replacement?
Dec 09, 2017 | Cars & Trucks
On a2000buick century odometer not working
You would need to take it to the dealer or someother qualified repair shop that has the diagnostic tool to check for DTC'S - diagnostic trouble codes in the instrument cluster .
DTC B0570 Season Odometer Malfunction
The instrument cluster receives a vehicle speed input from the vehicle speed sensor (VSS) over the Class 2 line. This signal is used in order to drive the speedometer and the odometer of the instrument cluster. The instrument cluster will compare the VSS data with a 16-point look-up table in order to determine needle deflection. A smooth filter is used in order to secure a continuous response. The season odometer displays the total accumulated kilometers (miles) of the vehicle. This value is permanently stored in the Electronically Erasable Programmable Read Only Memory (EEPROM) of the instrument cluster. The trip odometer displays the accumulated kilometers (miles) to the tenths of a kilometer (mile) since the last reset. This value is stored in Keep Alive Memory (KAM) of the instrument cluster.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Always perform the Instrument Cluster Diagnostic System Check before attempting to diagnose this DTC.
This diagnostic procedure requires using a scan tool.
This repair procedure requires instrument cluster replacement.
Step
Action
Value(s)
Yes
No
YES - Go to Step 2
Using a scan tool, clear the instrument cluster DTC and retest for DTC B0570.
Does DTC B0570 reset?
Go to Step 3
Go to Powertrain On Board Diagnostic (OBD) System Check in Engine Controls - 3.1L or Powertrain On Board Diagnostic (OBD) System Check in Engine Controls - 3.8L
Is the repair complete?
System OK
© 2017 General Motors Corporation. All rights reserved.
Feb 27, 2017 | 2000 Buick Century
Which terminals on obd do you short to get dtc,if you don't have scanner
What year an make vehicle ? Before 1996 you can do that on some make vehicles , not all ,GM cars mostly ! 1996 an above need scanner for all vehicle makes !
Aug 08, 2015 | Cars & Trucks
1998 blazer 4x4 cannot get it into 4 wheel high when i pus the button th4x4 and low range lights both blink and it goes back to 2 wheel high
Transfer Case Shift Control Switch Indicator Flashes and Returns to Original Mode.
Circuit Description
This symptom usually occurs when a shift into or out of 4LOW will not occur. When the transfer case control module (TCCM) receives a request to shift into or out of 4LOW, the TCCM must see the following parameters before the shift routine can start:
The vehicle speed must be below 3 MPH.
The transmission must be in neutral.
If the TCCM does not see these conditions the shift control switch indicator lamp will flash for approximately 5 seconds and then return to the original gear.
Test Description
  1. This step tests the operation of the transfer case shift control switch to help determine if the system is operating properly.
  2. This step determines if the vehicle speed sensor reading is correct.
  3. This step determines if the park switch reading is correct.
Switch Indicator Lamp Flashes and Returns to Original Mode
Step
Action
Value(s)
Yes
No
Schematic Reference: Transfer Case Control Schematics
Important: The transfer case shift control module is not a class 2 device, and therefore a scan tool can not be utilized on this transfer case.
Did you perform A Diagnostic System Check?
Go to Step 2
  1. Start the engine.
  2. Place the transmission into NEUTRAL.
  3. Set the park brake.
  4. Depress each of the shift control switch buttons.
Does the transfer case range change with the press of all of the shift control switch buttons?
Go to
Testing for Intermittent Conditions and Poor Connections
Go to Step 3
Use the scan tool in order to read the vehicle speed sensor on the transmission control Data Lists.
Is the vehicle speed within the specified range?
0 km/h (0 mph)
Go to Step 4
Go to
Powertrain On Board Diagnostic (OBD) System Check for the 4.3L engine
  1. Put the transmission in neutral.
  2. Observe the current state of the transmission on the scan tool in the transmission control Data 2 List.
Does the scan tool indicate the transmission is in Neutral?
Go to Step 5
Go to
5
Replace the transfer case shift control module. Refer to Transfer Case Shift Control Module Replacement .
Go to Step 6
6
Operate the vehicle within the conditions for causing the symptom as specified in the supporting text.
Does the symptom re-occur?
Go to Step 2
System OK
Feb 12, 2015 | 1998 Chevrolet Blazer
Speedometer works but not the rpm gauge 98 Tahoe 5.7
The speedometer is operated differently then the tachometer. Tachometer
The tachometer displays the engine speed in revolutions per minute (RPM). Voltage pulses are taken from the ignition control module (ICM) (Gasoline) or the generator (Diesel) and sent to the tachometer. Solid state circuits convert the pulse frequency in order to move the pointer of the tachometer.
Tachometer Inoperative (Gas)
Step
Action
Value(s)
Yes
No
Did you perform the OBD II System Check been performed?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check (5.0L/5.7L); Powertrain On Board Diagnostic (OBD) System Check (7.4L)
Remove the I/P Cluster.
Disconnect the Ignition Coil connector.
Connect a J 39200 DMM (continuity) between I/P Cluster connector cavity 6 and ground.
Is continuity present?
Go to Step 3
Go to Step 4
Locate and repair the short to ground in CKT 121 (WHT) between the Ignition Coil and the I/P cluster. Refer to Wiring Repairs in Wiring Systems.
Refer to Instrument Cluster System Check
Connect a J 39200 DMM (continuity) from I/P Cluster cavity 6 to ignition coil connector cavity B.
Go to Step 5
Go to Step 6
5
Replace the I/P Cluster. Refer to Instrument Cluster Replacement .
6
Locate and repair the open in CKT 121 (WHT) between the Ignition Coil and the I/P Cluster. Refer to Wiring Repairs in Wiring Systems.
Dec 26, 2014 | 1998 Chevrolet Tahoe
What is the different between obd1 and obd2?
OBD-I was implemented to help diagnose the earliest Automotive on-board computers by monitoring certain parts of the systems electronically controlled fuel and ignition systems. But individual manufacturers were allowed to design their own diagnostic systems, which made it necessary for mechanics to have different software to access the data from various brand vehicles.
Manufacturers started incorporating OBD-II in various models as early as 1994. All cars built since January 1, 1996 for sale in North America have been required to have OBD-II systems. This system features standardized trouble codes for all makes of cars for most common problems. It also provides almost complete engine control and monitors parts of the chassis, body and accessory devices, as well as the diagnostic control network of the car.
This provides the ability to communicate with Body Control Modules which control things like Anti-Lock Brakes and Traction Control, Active Suspension systems, Anti-Theft systems and many other items not related to engine performance like the earlier systems were confined to.
There are some hot sale obd2 diagnostic tool http://www.xcardiag.com/search/?q=obd2
May 04, 2012 | Cars & Trucks
Wats the code p1000 on my 2002 jaguar x type
P1000 JAGUAR - On Board Diagnostic System Readiness Test Not Complete, this is known as the OBD2 drive cycle.
Possible causes - The vehicle is new from the factory.
- Battery or Powertrain Control Module (PCM) had recently been disconnected.
- An OBD monitor failure occurred before completion of an OBD drive cycle.
- PCM Detected Trouble Codes (DTC) have recently been cleared with a scan tool.
When is the code detected? If DTC P1000 is triggered after DTCs have been cleared, all engine management OBD diagnostic monitor drive cycles have not been cleared. P1000 JAGUAR Description The On Board Diagnostic (OBD) monitors are performed during the OBD Drive Cycle. P1000 is stored in continuous memory if any of the OBD monitors do not carry out their full diagnostic check.
Feb 18, 2011 | 1999 Jaguar XK8
Can you please tell me were is the Diagnostic Link Connector located in a 93 Jeep Grand Cherokee?
You have what is called an OBD 1 system on board diangostic 1every thing before 1996 had this system . So an OBD 11 code reader will not link to an OBD1 or even connect to it . The OBD1 systems connectors are usealy somewhere near the battery they look like odd shaped connectors that don't hook to any thing there may be one or two of them . The problem with OBD 1 was you need a differant code reader for every major brand of vehicle GM dosn't work with ford dodge may work with with AMC jeep im not sure so your going to have to do a little home work to find one of these readers because you can't find them in parts stores anymore good luck
Feb 06, 2011 | 1993 Jeep Grand Cherokee
Did not pass state inspection (vehicle)
First the fault codes,
U110C is No Fuel Level Bus Message
U0155 is No Cluster Bus Message.
Unfortunatly you have to be able to communicate with the instrument cluster with your scanner to diagnoise and I do not think an aftermarket scanner can do this.
Mar 02, 2010 | 2005 Chrysler PT Cruiser
Dell Dimension 2400 PC Desktop Logo
2,213 people viewed this question
Alun Cox
