This laptop is the ONLY computer in the house that cannot find/connect with the wifi signal. The bios is showing blue and the wifi button is on. I bought it yesterday;entered WEP key and SSID....do I have to enter some kind of code?? All I have is 3 symbols showing a red cross through a screen at bottom right.
That indicates your wifi is on but not active, pull out your owners manual to make sure you did not overlook something, right click on the wifi icon, what do you see? The WEP key is assigned by your internet provider so long as you clicked on the right one you should be connected. If you still have problems contact your provider and have them give step by step instructions.
SOURCE: WPA on a hp ze4805us laptop
The ZE4805US contains the Broadcom or the LAN express wifi cards so dont expect a driver - the chip doesnt support the feature.
Hope this helps
SOURCE: HP zt1150 laptop has red screen instead of blue at
take the display on an extarnal monitor,
if it works fine on external then there is a problem in the lcd or in the wire conecting the lcd to the board.
dont forget to vote.
Testimonial: "Great ! this response is perfect . tried on external screen and was perfect . Thanks so much . A1++++++++"
SOURCE: my hp nc6000 wifi is not working as no light turns on even
try to reinstall your Wireless network setup
here's the link of your laptop driver
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=367369&prodSeriesId=367367&swLang=8&taskId=135&swEnvOID=1093
SOURCE: the laptop requires the Bios password to enter
Just visit this or click here
Enter your model and hash code and they email back your bios master password for your Laptop/computer.
SOURCE: Dear sir My HP ProBook4510s showing
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
