Question about HP PSC 1315 All-In-One InkJet Printer
Will not print. says out of paper but there is paper in the tray.
Printer attempts to print but will not pick up paper, then sends a message -printer out of paper.
  • anita_wilson Nov 13, 2008
    The printer is a little over a year old. It is mainly used to print home work assignments for my kids, not a lot of hours. When I send a job to the printer I hear it calibrating then I hear what sounds like the rollers trying to pick up the paper. Next comes the red light check paper and the error message printer out of paper. I've checked to make sure there is not a paper jam and there doesn't seem to be any paper or remnants in there. Your help will be appreciated.
  • Frank
    Frank May 11, 2010
    how old the printer?
    how is th eprinter is used? lots hours??
  • 1,605 Answers
This is indicate that the roller is having some kind of problem.
open the backdoor, make sure there is nothing preventing the roller (should be 3) do its job.
take out the paper from the paper tray. make sure there nothing in the way of center roller path.
re position the paper. load enough paper, so that the paper is right under neath the center roller, remove 2 sheet. try to print. if it pickup the paper, then it is telling you that the roller need to be replaced. if it still having problem pickup the paper. then there is something else we need to investigate.
Hp always being having problem with their printer roller since day one. over time the roller become smooth, and not able to pick up paper.
if the porblem presist, please repost it in this thread. so I can help you to solve the problem.
Posted on Nov 13, 2008
How do I get my HP2575 printer to pick up the paper in the paper tray?
Hi jtheiss,
When you send a print or copy to the printer does the pickup tires attempt to pickup the paper?
Apr 12, 2012 | HP Photosmart 2575 All-In-One InkJet...
OfficeJet Pro 8600 will not pick up glossy photo paper from the tray
I tried everything that was suggested on the HP forum but then tried something not reccommended there and it worked. Not only remove tray 2 from the printer properties but force the print to tray 2, when you this it sets the Quality from normal or Best to Custom. Once I done that it worked... Just disabling the tray 2 is not enough.
Mar 26, 2012 | HP OfficeJet Pro K8600 Printer
Reading no paper paper tray is full
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Not picking up paper
Most new printers and copiers will attempt to feed paper several times before failing and giving a jam condition. It sounds like that is what is happening to your printer.
Your tray rollers may be dirty. Remove the tray and use a clean cloth with mild detergent to clean the rubber rollers. Do not use alcohol this will dry the rollers out. If problem continues replace the tray rollers.
May 18, 2010 | Samsung CLP 300 Laser Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Hp 4250 manuall feed heavy paper message
You'll have to set up the paper settings within the copier to reflect heavy paper for the bypass tray. You'll need to make this a default setting. Then when you print out with heavy paper via the print drivers it should pick up automatically at the printer.
Aug 28, 2009 | HP LaserJet 4250n Printer
'Printer out of paper' message
on note pad or word you should select the paper size first because it might set to a different size. when you click file click print click properties or printing preference and choose what size of paper you have in your tray and then click ok. print ok.
check the printer paper tray setting to make sure the paper tray side guide is right agains the paper. I hope this will solve your problem.
Aug 12, 2009 | HP LaserJet 5p Printer
Error message keeps appearing "paper jam in tray 2" although there is definitely no paper jam.
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it.
May 02, 2009 | HP LaserJet 2300dn Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
128 people viewed this question
Ben Johnson
