Question about HP Officejet J5780 All-In-One InkJet Printer
All of a sudden scanner, copier and fax stopped working.
Tried reinstalling but it didn't work. Continuous message "Aligning cartridges, please wait." I can still print from the computer.
  • 5 more comments
  • sandaliog1 Nov 15, 2008
    A window comes up in my PC showing "Scanner Failure", "Cycle power and try scanning again." I'm not even trying to scan, only to copy. The printer (HP Officejet J5750) displays message "Scanner Failure, unable to scan, copy, or send a fax. Press OK." When I press OK it starts realigning print cartridges and I get the same scan failure message.
    Didn't work, got the same scanner failure message again.
    Printer Test Page came out OK, but the message in the printer is still "Aligning cartidges, please wait."
    There is no code.
    I checked that page, cartridges are OK.
    Nope, none of that worked.
    Thanks. I'll get a new one, not worth the hassle.
    President:
  • 1,952 Answers
Exchanging the XL and replacing it with the regular size cartridge the error message went away.
Posted on Nov 15, 2008
    Guru:
  • 859 Answers
When these products are prepared for shipment to the vendor for the end user to purchase there are implements place in the works of the multipurpose printer to keep moving parts from slapping around. This runs from a movable tab to lock the scanner arm, to pieces of cardboard placed so the printer carriage doesn't move in shipment.
What your situation sounds like it that the scanner arm is still locked in shipping mode. There has to be a slide locking tab, not just a piece of cardboard that has two positions marked on the unit. One position for shipping and moving and one for use.
This sounds like the case in your situation. I would either read the large blowup instructions, or the users manual for a guideline on where to find this should you not be able to spot it on your own.
Good luck, and good hunting. I'm here to follow up on any questions before you refuse and move on to the next.
Worldvet
    Brigadier General:
  • 6,966 Answers
Initially, pls try a soft reset by pressing and holding # & 6 buttons while plugging in the unit to the outlet and try again. Should this be not corrective, then it is a hardware fault in the scanner engine. You may have to weight your options and consider repair cost plus downtime versus replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • 101 Answers
  • 728 Answers
Try printing a test page which will automatically align the cartridges by going to control panel, clicking on printers and faxes, finding your printer in the list, right clicking on it and going to properties, and at the bottom of that page, it will say print test page.
  • Jazz Boyce
    Jazz Boyce Nov 15, 2008
    Try unplugging it overnight to let it reset and see if that makes any difference. If not, make sure those are the right cartridges for the printer or else the printer will keep saying that it is trying to align. The cartridges you have now may not be recognized by the printer and that is why it is saying that message.
  • 73 Answers
Did you align the cartridges?
If so--> try this-->shut all the system --> unplug the printed--> take the cartidges out of the printer--> start the system again--> install the cartridges again
  • HP Master
  • 685 Answers
Is the aligning right on the printer? if so try turning it off and unplugging it for about 10 seconds and plugging it back in and see what it tells u.let me know what happens.
  • 2 more comments
  • Juanita Vega
    Juanita Vega Nov 15, 2008
    is there a code when it does this?
  • Juanita Vega
    The message
    'Scanner failure, Power off and on'
    displays on the control panel of the product. This error can occur when
    you try to scan or make copies, or when the product is warming up after
    you turn it on.
    Try the solutions in this document. It is not necessary to continue to the next solution, if one solution resolves the issue.
    Solution one: Check the scanner light
    Make a color copy of any document by pressing the
    Start Copy Color
    button on the product control panel. While the product is making the
    copy, lift the scanner lid slightly to see if the scanner light is
    visible.
    • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to
      Solution six: Service the product
    • If the light is lit, proceed to the next solution.
    Solution two: Check operating conditions
    Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the
    User Guide
    provided with the product.
    Solution three: Check the power connections
    1. Make sure that the part number on the power supply matches the part number listed in the
      User Guide
    2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
    3. Try making a color copy by pressing the
      Start Copy Color
      • If the copy job is successful, you do not need to continue troubleshooting.
    4. If
      the error message displays again, temporarily move the product to a
      different room, or plug the power cord into a different wall outlet.
    5. Try making a color copy by pressing the
      Start Copy Color
      • If the error message displays again, proceed to the next solution.
    Solution four: Perform a power cycle
    1. Turn the product off.
    2. Unplug the power cord from the product.
    3. Wait 30 seconds, and then connect the power cord to the product.
    4. Turn the product on.
    5. Make a color copy by pressing the
      Start Copy Color
      button on the control panel.
    Solution five: Reset the product
    Follow these steps to reset the product.
    Step one: Perform a partial reset
    1. Disconnect the power cord from the product.
    2. Press and hold
      and
      while reconnecting the power cord to the product, and then release both buttons.
      Start Copy Color
      • If the partial reset resolves the issue, you do not need to continue troubleshooting.
      • If the error message displays again, proceed to the next step to try a semi-full reset.
    Step two: Perform a semi-full reset
    2. Press and hold
      and
      6
      Start Copy Color
  • Juanita Vega
    try this and let me know
  • Juanita Vega
    is there anyway you can text me so we can talk about this as your doing the work on it?if so you can text me at vegakitten2008@yahoo.com
After replacing 901 black cartridge printer keeps saying aligning cartridges please wait
every time replacing an ink cartridge, printers asking for alignment.do it once , following instuctions which appears in printers monitor.after,look at printed page and saw if is asking to scan once this page.
Feb 15, 2015 | HP Officejet 4500 All-in-One -...
I have an HP 6110 all in one printer. I get a continuous error message saying to align printer cartridge although the cartridges seem to be loaded correctly. I have replaced the cartridges even though they...
you need to align your printer cartridge, to align the cartridge go to start button on your computer desktop then click the setting and choose the printer and faxes then right click your installed printer HP 6110 then choose the properties of your printer then you click the maintenance menu then you see an option to align your printer cartridge...just click it and wait until finish aligning your cartridge..
Mar 02, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Message sez
Check this out. See if it helps...http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00657&cc=us&lc=en&dlc=en&product=422000
Jun 09, 2009 | HP PSC 2355 All-In-One InkJet Printer
Continuous Alignment Message, Please Wait.
Click here and follow the instructions to do a partial reset on your printer and try to align cartridges. Click here for instructions to align cartridges.
Jun 08, 2009 | HP J3680 Officejet All In One Printer
Scanner stopped functioning
r u already try reinstall your driver?if not, try it 1st and see the result..i'm afraid the driver is damages....try to download from canon support website in order to get the updated one...hopes it will help ; )
May 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Pressed ok more than once to start alignment??
Have you worked through this page already? And you tried the "Bypassing the print cartridge alignment" solution? See HP's solution here. Make sure you don't have photo paper or colored paper in the input tray when aligning...
When you perform the reset, did you unplug the data cable (usb) as well as the power, and wait a few minutes? Try leaving both data and power cables unplugged for 1/2 hour and then resetting, and make sure you complete the power cycle by pressing start copy color. Link here.
If none of these steps work, try removing and reinstalling the cartridges, and if that doesn't help, here's a last ditch fix that may work in your case.
Otherwise, I'm afraid service is the answer...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 23, 2009 | HP Officejet 5610 All-In-One InkJet...
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
My Hp officejet 5610 isn't working
Hi ,
when u aliiging cratridge u get one printout , take this print doc & placed on the scanner glass to scan it & press scan bottun for properly aliige cartridges ..this is the right prosiger for allign cartridge
if this information is useful for u please Rate me................
Jun 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Alignment of cartridges
Please click on the web link given below and perform the steps as provided in the web page to get the issue fixed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042820&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Jan 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
