Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
I cant get onlin
Hi, I have installed the adapter but keep getting "limited or no connection" status notices, when I go through the repair connection promt it ends with an invalid IP Adress as the reason for problem ???
  • Trish
    Trish Nov 19, 2008
    I am having the same problem , i have a wireless G plus MIMO usb adapter and i connect via satellite connection and ip is assigned by DHCP , very frequently I get disconnected and nothing would other wise indicate that i am disconnected other than the belkin wireless network utility. The wireless connection properties indicate i am still connected , until i click the support tab and view the connection status where it then says invalid IP address. This happens intermittently all the time and i have tried to figure out what the problem is but alas i have no answers. Usually 1 or 2 reboots will remedy the problem but if anyone has an answer for this i would be eternally grateful.
  • Jannette Amandy May 11, 2010
    What is the model of the wireless router you have?
    It is possible that your wireless network requires a network key.
    President:
  • 2,992 Answers
I have seen this kind of strange behavior when the adapter is bad. No network detection, or connect but no webpages would ever come up, weird problems. All cleared up by replacing the adapter with an identical one, so it was not because of any settings or software issues. A new adapter is probably needed.
Posted on Dec 04, 2008
My laptop has been switched off for a week. when i turned it back on, it cant find any wireless networks or my wireless router. i can only get online by manually plugging the yellow lead from pc to router....
- It seemed that there is no wireless network driver that is installed on the computer
- I also noticed that you can connect to the internet using a wired connection
- you can download the wireless driver using the computer manufacturer's support website (e.g support.hp.com if it is a hp laptop , support.dell.com if it is a dell laptop)
- if laptop is customer built you can go to start -> run -> msinfo32
- Under system summary-> components -> network you can find an idea what kind of wireless network driver you have
- and you can google and download the wireless network driver
May 16, 2011 | Computers & Internet
Why i cant use enternet
Are you getting limited connectivity or is the status "A network cable is unplugged"?
When you have limited connectivity, you are connecting to your router but not getting an IP address for the Internet, so the problem could be with your router.
Try to disable/enable the network adapter.
Reset the router.
If there is no connection at all, you may have a defective cable, try replacing the cable.
May 02, 2011 | Microsoft Computers & Internet
Limited or no connectivity
hi,
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | Adapters.com PLANET USB WLAN...
Limited or no Wireless connection
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
Feb 09, 2009 | IBM ThinkPad T41 Notebook
Wireless network connection
Mine always does that when my IP address lease renews but it's an easy fix. You can usually click on the pop up that says limited or no connectivity then in the box that comes up click repair. If you cannot get to that box you can just go to start>control panel>network connections then right click the wireless network connection then left click repair. That usually works for me.
Hope that helps!
Jill
Nov 30, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Connection problems
i think that if your ipaddress will not properly.second thing is that if your firewall is on then off that one or proxery server is there also show this message
or your dns value. if you using dhcp then you give the ip address then also not come the internet.
try this things
Jul 11, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Password Problems
Maybe you are getting LIMITED OR NO CONNECTIVITY. This happens when the wireless adapter is able to find a network but the pc cannot get an ip address. One of the reason for that is that your wireless network might be secured and you missed to enter the correct network key when you were asked by the computer. The wireless security is set on the wireless router, SO WHEN YOU SET THE PROFILE ON YOUR WIRELESS ADAPTER, YOU SHOULD ALREADY HAVE THE WIRELESS SETTINGS FROM YOUR WIRELESS ROUTER. THEY HAVE TO MATCH FOR YOU TO HAVE A COMPLETE CONNECTION.
Mar 10, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
Problem in wireless connection and showing limited access
typing incorrect password weather in wireless setting or in computer
Jan 28, 2008 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Installing a 32 bit air link wireless cardbus adapter AWL C3025
First have you tested a wired computer to assure all but the wireless section is configured correctly?
Second have you tested a wireless unencrypted connection to assure it works?
When choosing an encryption strategy did you assure the router and adapter supported the same choice. Generally there is WEP and WPA -- most people prefer WPA now however both the adapter and the router must support it to make it a viable choice.
To provide further assistance please check the model number of the router and provide either the manufacturer and model for the wireless adapter or the computer with a built-in wireless adapter you are attempting to connect.
Dec 06, 2007 | Airlink (AWLC3025) Wireless Adapter
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
140 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
