Question about Hamilton Beach BrewStation 47214 Coffee Maker
Stops brewing before done
It passes about half the water through, and then stops. Any suggestions?
  • Todd Jenkins Nov 30, 2006
    Found the answer. I ran vinegar and water through it, and it worked!
  • Anonymous Jan 10, 2008
    I used the cleaning solution that came in the box. Coffee quicks brewing about every 2 cups. This did not solve my problem. My brewstation is only 1 month old.
  • 944 Answers
Http://www.hamiltonbeach.com/cgi-bin/main/co_disp/displ/strfnbr/20/pgname/usecare_coffeemakers explains this procedure in detail if anyone else has the same issue. Hope this helps :)
Posted on Mar 15, 2007
I just bought the Bunn VLPF series, double burner. My other Bunn coffee pot had the option of make a half pot of coffee but this one does not Is there a tip to follow for half a pot?
Sorry this brewer is usually set up for a full pot brew. I have reset this for a small (but not half) pot brew as the customer wanted to use a metal carafe (with their own logo). I also tried once to get it to half pot brew but it can get tricky if you actually brew twice to get a full pot (in the same pot).
* there is a siphon action that starts once the boiler tank gets filled to a certain point. From that point it will continue to flow until the boiler is emptied to the level that stops the siphon action and leaves enough water in boiler to reheat for the next brew. Achieving the siphon point may be a larger volume of water for 1/2 a pot but may work for 3/4ths a pot. The 1/2 way mark may be affected by the brewers "level" while placed on a table or sagging in the middle of a weak table.
* Usually if you want a smaller brew then go with a smaller brewer. Though there is a hot water tap that will give you 2-4 cups of hot water (it gets tepid after that) which you can use for the "Mug" style brew. But it does get messy.ukeboy57
* Final, If you don't mind a little more than 1/2 pot brews then ask your vendor to adjust the machine for you. Though a reminder NOT the double brew in the same pot as it will overflow.
Aloha, ukeboy57
Dec 28, 2017 | Bunn Coffee Makers & Espresso Machines
Krups savoy stops half way through brewing cycle
Have you tried a cleaning cycle of vinegar in the water tank. Sediment might be the issue. Many coffee, etc machines with water use and not using distilled or cycle water systems will have the thin crust create issues. Lime is the word.
Oct 17, 2017 | Krups Coffee Makers & Espresso Machines
Brew group/thermostat ?
Definitely sounds like an overheating issue. Especially if you have to wait a half hour for it to cool down and then it brews again. If it is under warranty I recommend replacing it.
Jan 24, 2014 | Saeco Vienna De Luxe Espresso Machine
I PUT SWITCH ON FULL BREW AND IT STOPS WITHIN 30 SECONDS. WHEN I PUT IT ON HALF BREW IT DOESN'T STOP RUNNING
It sounds to me like the Timer board is damaged, to test it set the small lock lever on the board to on (hopefully you have the electronic timer board in there) then select the cycle half or full then hold down the brew button until you hear 3 clicks then release. After about 1min or if using a measuring pitcher stop the brewer a 2ltrs, by turning the on/off switch off. Wait until flow stops then check water level and note. Turn brewer back on and press and release brew button and this time if it stops and gives you the same amount as you just got when programming then the timer is fine, just recalibrate it for full brew using the method above.
May 18, 2009 | Bunn U3 / SS 20500-0000 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Auto shutoff
some of these coffee makers have feed tubes, which can be seen in the rear water reservoir, that feed the hot water to the grounds. some of these tubes collapse when the boiling water passes through them , then kink , causing the water to stop flowing untill it either cools or is straightened. To check and see if this is occuring.. look in the back reservoir, if there's a tube running through it, note how soft it gets as it starts to brew.. be careful the water inside the tube is hot.. This indentify why it stops brewing partway though..
Sep 21, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Hamilton Beach BrewStation 47214 Coffee Maker Logo
437 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Marvin
Marvin
80stech
Joseph Hoffmann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
