Question about Lexmark X2500 All-In-One Printer
Finding correct Cartridge ?????
X2500 Printer. Printer cane with cartridges # 2 and #3 Replacement calls for No. 28 and 29. Computer does not reconize these cartridges for this printer. I compared these cartridges with the 2 and 3 and not the same. What next ???????
  • prettau2 Nov 22, 2008
    Thanks for trying, didn't work on mine.
#14 black #15 color it has to be lexmark ink only...it will not accept any others.....if you have a walmart where you stay at they should have a little machine by the ink cartridges....use that...that is where i got this info from and my printer is printing just fine
Posted on Nov 19, 2008
Describe your X2500 All-In-One Printer Problem I purchased Lexmark brand printer cartridges and installed them correctly. The machine believes that there are not cartridges installed. I had previously...
The error could be to either a communication problem between one of your cartridges and the printer or a short in one of the cartridges.Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Aug 29, 2011 | Lexmark X2500 All-In-One Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    X2500 All-In-One Printer: why says the black and color cartridge replacement...
    Check to see if the installed cartridge is the correct one for the printer. If the cartridge is the proper part number, remove the ink cartridge and make sure all the packaging tape has been removed from the copper circuitry strip on the backside of the cartridge. Reinsert the cartridge and try printing again.
    If the error continues, remove the cartridge again and clean the copper circuitry strip on the backside of the cartridge, and the contacts inside the printer, by following the instructions below:
    1. Use a clean, dry, soft, lint-free cloth. Locate the copper-colored circuitry strip on the back of the cartridge.
    2. Wipe the copper-colored strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. Wipe the contacts only once.
    3. To clean the printer contacts, carefully look for fibers or contamination on the electrical contacts inside the carriage assembly, but do not wipe the printer contacts with any object. The contacts in the printer can be damaged if too much pressure is applied during a wiping process. Try to remove any visible attached debris within the carriage assembly by gently pulling the debris off with your fingers. If the carriage contacts show noticeable damage, contact the Customer Care Center listed in the printer's User's Guide.
    Reinsert the cartridge and try printing again. If the error continues, the cartridge may need to be replaced.
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    May 18, 2010 | Lexmark X2500 All-In-One Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark printer always want a new cartridge
    What you need is to reset the ink level:
    1) Goto the Lexmark Solution Center application.
    2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
    Hope this help.
    YBC (/\)
    Feb 18, 2009 | Lexmark X2500 All-In-One Printer
    Need replacement cartridge for my X2500
    You can order them from Lexmark. (A bit expensive.) Links below.
    #2 Cartridge
    #3 Cartridge
    Also available at Circuit City:
    #2 & #3 Combo
    Nov 22, 2008 | Lexmark X2500 All-In-One Printer
    Installing new ink cartridge
    bought a new cartridge for x3430, replaced old one and it says: "missing cartridge". I have re-seated it a million times but to no avail.
    Aug 19, 2008 | Lexmark X2500 All-In-One Printer
    NO CARTRIDGE
    Either return to staples and purchase a new cartridge, or order from lexmark. If you are talking about getting the one they didn't include, you will have to speak to lexmark customer service or bring the printer back to where you bought it.
    Jul 11, 2008 | Lexmark X2500 All-In-One Printer
    Ticket # 49578
    If you bought your printer as part of a pakage from Circuit City it may use cartridges only supplied by them. In that case it's a #2 and a # 3. I had the same problem, they don't tell you that though.
    Jun 12, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark x2500
    Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
    Mar 25, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X2500 All-In-One Printer Logo
    78 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
