Gateway backlight went dark
I have a gateway 400sd4 laptop and the screen went dark. I can see faint images. I this just the back light, inverter, other? Can I repair it myself or do I need to take it in for service.
    Problem Solver:
  • 9 Answers
Yes you are 50% right. The problem with your laptop is either the inverter module or the backlight itself. If you have a little electronic background and have the correct tools, you might be able to repair it. Although, its more practical to replace it with a new one. It is normally located on the lower front part of your LCD panel. If you can remove the front cover of the display, the you will find it on the lower part. It normally have two connectors, one comes from the mainboard, and another (2 wires) goes directly to the backlight.
Posted on Nov 13, 2008
Cant turn brightness up on screen
IS the screen really dark and can you see a "ghost image" when you tilt the laptop back, looking along the edges? (from an acute angle)
IF you do see a faint image, your laptop screen's power inverter may be bad, or the screen's "back light" may be bad... Take it to a shop to have them verify this issue. Hope this helps.
Dec 10, 2013 | Computers & Internet
Sony Vaio E Series VPCEH37FX screen goes dark, but fine otherwise
If you can see faint dim images on the screen, then your back light or power inverter has failed. They are not adjustable or repairable and must be replaced. If you can't see anything on the screen, the LCD has failed and must be replaced. Sometimes it's hard to see the dim images so use a flashlight to help determine if there is any image on the lcd.
Oct 27, 2013 | Sony VAIO Computers & Internet
A125 monitor is dark
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 02, 2013 | Toshiba Satellite Computers & Internet
Blank screen on my dv9608ca laptop i changed power inverter and screen its very dark can faintly see desk top items. everything works when in connect to different monitor so can it still be video card
It sounds like your laptop's Back Light is out. The screen has two layers, the LCD display, which provides the image, and the back light, which gives it brightness and clarity. Unfortunately, it is no easy fix and typically costs more than a new laptop to replace. I'd recommend calling HP themselves if you want to get it repaired.
Aug 26, 2011 | HP Pavilion dv9608ca PC Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
Screen went black and laptop still on
power off the laptop, leet it cool, then check again, if not then clean the memory module with an eraser, or try connecting an external monitor and let me know if the problem reapets.
Dec 25, 2010 | Compaq Presario CQ60-220US PC Laptop
Blank screen HP DV1000 I can get video on an external monitor though
Your laptop may have video options:
* only internal LCD screen
* only external monitor (leaving your screen "dark")
* both screens.
Try toggling through the above 3 options.
After that, there's no part in the LCD screen that you can repair, by yourself.
So, if the computer is still under warranty, contact HP to exercise the warranty.
Otherwise, take the printer to a qualified technician, for proper trouble-shooting & repair.
Dec 10, 2010 | HP Pavilion dv1000 Notebook
I have an NEC '19 Multisync LCD 1920nx monitor. The display went blank and will not come back on. There's power going to it. It just doesn't display and image. How do i fix this?....thanks
the inverter or the lcd bulb may be out. inverters are cheap, bulbs are not. is the screen dark like its off or glowing black? if its dark like the bulb is off, next, look closely and see if you can make out a faint image on the dark screen, if so, it is likely the inverter.
Aug 05, 2010 | Mitsubishi Computers & Internet
Screen is dark (like there is no power on it)
Well if you take a strong light like a flashlight and you can see a faint image. Then the lamp (CCFL) or the lamp's inverter has failed. It should work fine with an external monitor. Still not good though and usually expensive to repair (unless it is still under warranty).
Jan 31, 2009 | HP Pavilion dv6000z Notebook
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
