Question about Toshiba Satellite M35X-S111 Notebook
Overheating I have a Toshiba M35X-S111 laptop. The fan goes on at the beginning of boot-up, but then shuts off... and doesn't go on again. Basically the computer ends up heating up. Is this a problem with the fan or is it something else? If so... what would it be? I'm guessing something else as the fan works at the beginning so something controlling it staying on might be bad?
  • rbetel Nov 13, 2008
    Any other ideas. The inside is perfectly clean...
  • 88 Answers
Yes. normaly fan switched on automaticaly when the microprocessor warm up. inyour case some time the sensing of microprocessor and fen contorler had the problem .however you open your laptop and trying blow up with the vacum cleaner to do clean dust deposited inside your laptop mostly it will help to slove your problem.
trying up to your satisfaction.
Posted on Nov 13, 2008
  • if your fault still remain
    1.remove the fan socket. and apply 5-12vDC. and obsrerve the Fan run quitly
    or sturckup some time.
    if fan ok
    .check for other functions are ok
    if some times you have any othrer problem
    check ur Powersupply unit also.
    2.if fan dosen"t run sothly replace the Fan.
M35X s111 won't boot
is the drive making any sounds, beeps, or sounds like clicking after revving up? Might need new hard drive, I had same laptop do the same thing, when it got to post, cursor of death= hard drive died. Also note that you need to replace it with a low GB drive, ATA or SATA not IDE. Try and get 80 - 120 gig if it does need replacing. For some reason I remember it wont run anything over 240G.
Good luck.
May 30, 2014 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satelite M35X-S111 Beep codes on boot
You need to go into the BIOS (setup) and reset to factory defaults first. This should clear up the issue.
May 28, 2012 | Toshiba Satellite M35X-S161 Notebook
Hi, I have a toshiba m35x-s111, I was not using it for a few months because the monitor is damage. I tried starting it and now it comes on for a few seconds and then stop. Will not boot from recovery...
This is a Maxim 1987, or in some cases Maxim 1532ETL power driver chip issue. The only solution is to resolder the chip. It's a tiny chip, but very doable with a fine pin soldering iron. It takes about an hour to do the repair. The chip is next to the power plug so you will have to take the motherboard out completely to do the resolder the Maxim 1987 chip. Basically, the point is to do an actual resolder, not a reflow.
Aug 30, 2010 | Toshiba Satellite M35X-S111 Notebook
After fixing power jack problem secreen will not lit
toshiba satellite M35X-S111
After solving the jack problem.
when I click on the start button I hear the fan voise but there is nothing on the moniter and no sound.
When I remove the connection between the start button and the mother board and put it again it works two times and then the problem started again.
The computer may work random at sometimes.
Is the problem in the small board and the cable which between the start button and the mother board ?
If yes how to purchase it
Dec 12, 2009 | Toshiba Satellite M35X-S111 Notebook
Toshiba satellite m35x-s111 will not power up
there was a massive recall on these laptops years ago entailing that the mother board be replaced. unfortunately that is gone and passed. this is a problem with every m35x and most honest repair facilities shy away from those repairs due to the likelihood of the machine failing again.
Oct 22, 2009 | Toshiba Satellite M35X-S111 Notebook
How can i reboot my toshiba M35x-S111 without a disc?
it's not necessary to have disc to reboot or shut down your PC.. This procedure is very simple to do.
Rebooting PC is necessary when sometimes its notice have a hang-up or low running system or uninstall program.
Aug 27, 2009 | Toshiba Satellite M35X-S111 Notebook
My toshiba m35x-s111 laptop screen goes blank
According to the description of the fault and the symptoms that your equipment presents, you must replace the FL inverter, that is the one that gives the turn on of the screen of your equipment, if your you replace this piece that one finds behind of the mask of the screen in the low part and that is similar to a pen I assure you that your equipment it was working in perfect conditions
Dec 23, 2008 | Toshiba Satellite M35X-S111 Notebook
Overheating
if fan is working well then it might have processor problem.
Nov 19, 2008 | Toshiba Satellite A105 Notebook
My M35X-S111 keeps shutting down
More than likely it is overheating you can buy a can of compressed air and blow it out if you dont have a compressor that should be done at least every 6 months
Aug 06, 2008 | Toshiba Satellite M35X-S111 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M35X-S111 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
