Remove the trim ring around the inside door handle by pulling it up and towards you first, then downwards.
Remove the switch panel. There are two spring clips holding it. Lever up carefully on the top end edge first, then push the panel towards the car floor. Disconnect the electrical connector.
Remove the screws behind the door handle, under the switch panel mount, and on the armrest.
Dislodge the 7 trim clips around the edge of the door trim, starting at the lower edge and working up. Lift the door trim out of the top channel.
If you remove the plastic sheet, take care not to tear it, a spatula is handy for this.
SOURCE: how remove the rear inside door panel on a 2001 oldmobile aurora
The inner door panel is held in by clips and screw.
Look at the door near the door handle there should be screws holding it in and along the outer edge of the door. Once loose, and the door handle removed or the arm rest removed. The door panel then prys out , because of the clips that hold it on. Then pops out by applying pressure to the panel upward to the top of the door. The clips always break because of the design and plastic.
Good luck
SOURCE: window dropped into rear door panel. How do I remove the panel & repair
the window regulator has failed. the door panel has to be removed first which requires removing the trim piece that is on the grab handle (extremely hard to remove without breaking) there are three of four screws that hold the door panel on. once the door panel is off, the vapor barrier has to be removed. don't tear it, it is there for a reason to keep water out of the vehicle. make sure you reseal it properly with window weld. once the vapor barrier is removed you will need to unclip the window glass from the regulator. i typically will take and break the tab that holds the window. once the window is loose, move the glass all the way to the top of the door. now remove the regulator, swap the motor over, and reassembly. i would recommend taking the vehicle to a bmw dealership, around $650 for the complete repair and the dealership will stand behind their repairs
SOURCE: Replacing a/c hoses in Subaru Outback 2004
give this website a try its about A/C-repair www.directgardening.com
SOURCE: rear door panel removal
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
SOURCE: How do I remove the REAR door panel on my 2004
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
