Question about Nikon D70s Digital Camera
Flash not working
I have Nikon D50. My built in flash will pop up but the bulb I think has blown out. Can I fix this myself?
  • grega1009 Jan 03, 2009
    I have the same problem with my D60. The flash will pop up and take the picture like normal but no flash. It is like the camera thinks it is flashing. Maybe a blown bulb?
  • 62 Answers
You have 4 wires in the head of the pop up falsh plus 330 volts are present .
That job is best tpobe done by a camera technician
Berrie Smith Camera Repair
bbmw@bellsouth.net
Posted on Nov 29, 2008
The flashgun doesn't pop up when it should. It remains jammed.
Ok
Its not clear how you are using the camera.
Check the settings on the left. Some settings (Landscape for example will not allow the use of flash)
Set the camera to P,S,A OR M and it will. In Auto it will pop up if it needs it. It It still won't work Look at the menu settings for Flash Mode two settings 1) TTL and the other Manual. I have my D50 set to TTL using the built in flash and manual when using an external flash mounted in the shoe.
Hope this helps
Dec 12, 2009 | Nikon D50 Digital Camera
Internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Dec 08, 2009 | Olympus EVOLT E-500 Digital Camera
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Flash on Nikon D50 will not latch down
If you have a fine screwdriver, remove the two screws underneath the pop up flash housing and remove the upper housing. BE VERY CAREFUL OF THE 300V at wires under the cover. You can see where the latch catches on a disk with steps - rotate the disk to a lower step and it will catch. Otherwise, an independent repair shop can probably do it while you wait for less than $40 USD.
Nov 25, 2008 | Nikon D50 Digital Camera
Nikon D50, digital SLR, I was using my camera at a wedding and the flash just stopped working. The camera thinks the flash is going off - it pops up and takes them quickly but no light goes off.... do...
good day,
it seems that your built-in flash is busted. you can go to your nearest nikon service center and have it replaced. or you can purchase an external flash that you can attach to your unit. when looking an external flash better use a nikon flash, however if you are looking for other brands/manufacturers, just check if it is compatible with your unit.
i hope this will help
Sep 27, 2008 | Nikon D50 Digital Camera
Flash
It may be broken/blown, but there is a way to toggle the flash. There is a button located on the left-front of the camera , just left of the flash and above the lens. Hold it while scrolling the wheel on the right.
Best way to find out if it's broke or not: put your camera on Auto, go into a dark room, and take a photo. If the flash pops up and takes a shot w/o firing, you know it's broke. If it doesn't pop up at ALL, you've probably got a bigger problem
Aug 03, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Flash: PCB Replacement v. New Bulb!?
I had the same issue. The flash is set to go off, the camera assumes it went off, (as the record metadata shows) but it doen't go off at all, and the piture is underexposed.
I bought the 100 page repair manual, which is ONLY a dissassemble/reassemble manual with NO diagnostics. (Got it on ebay) So I was atleast able to get to the capacitor and flash bulb. I saw 300V across the capacitor leads, and the same 300Volts across the flash bulb leads. SO I am assuming that there is a transistor or relay that drops to ground to fire the flash that isn't working, or the electronic signal to drive that isn't working.
It seems most people replace the entire flash circuit board(which is near the capacitor under the left hand side). But it seems Nikon only sells parts to it certified repair facilities.
Ugh.... Looks like I'm buying a SB-600, as this is the cheepest solution. Too bad, because the on-board flash is more than decent. I hope the SB-600 thrills me enough to change my mood. :)
Oct 07, 2007 | Nikon D50 Digital Camera
Built in Flash
I have the same problem on my D50. I found this forum, which sounds like it may fix that problem. I am going to try it out. http://forums.dpreview.com/forums/read.asp?forum=1034&message=22761542
Sep 25, 2006 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D70s Digital Camera Logo
219 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
