Question about 2wire HomePortal 1000HW DSL Modem and Network Router -1000-400210-000_LN_R (1000400210000LNR)
Dsl light flashes red constantly
The dsl light on my gateway 2wire router flashes red, and I can't get on the internet. My computer says I'm connected, but I get nothing.
  • 4 Answers
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Posted on Jan 14, 2009
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
The dsl light keeps blinking red no Internet connection
for LED LIGHTS interpretation: refer to this link:http://www.sasktel.com/search/controller//Internet/2Wire-Gateway-2700-2701-LED-Status-Lights-Guide/_/R-Support_13750/Record-Support
NOTE: everything that says contact SASKTEL TECH SUPPORT refers to your Internet Service Provider
Qwest Technical Support at 1-800-247-7285
SASKTEL TECH SUPPORT Anywhere in Saskatchewan :1-800-773-2121
Outside Saskatchewan (anywhere in Canada and USA):1-888-773-2122
Anywhere else in the world:1-306-522-1820
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Hope This helps
Aug 14, 2011 | 2wire 2700HG-B Router (2700HGB)
2Wire gateway is on and the DSL light keeps flashing. All eqpt is showing that it is connected to 2wire, but not internet connection. I keep getting athe message that broadband is currently...
the problem is with century link.. There server could be down because of some maintenance.. Wait for a while and it will start working as soon as the server is up..
Engr Aamir
Jul 02, 2011 | 2wire (2701HG-B) Wireless Router
My dsl light is flashing and the 2wire router just clicks over and over again. All other lights are on and green except for the Internet light (because dsl is flashing). Router has been working perfectly...
Hope This helps
Jun 25, 2011 | 2wire (2701HG-B) Wireless Router
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
Says dsl has no connection, but yet on network it says connected. red light flashing on gateway unit
Your computer sees its connection to the gateway - that's your "connected" - without being connected to the internet. First check that all cables are securely plugged in, especially the cable from the phone jack to the gateway device. You may need to cycle power on the gateway device to restore the DSL connection, and you may need to reboot the computer afterward to reconnect to the Internet (depending on your OS).
Jul 29, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2wire 2701HG-B constant power loss
Hard reset the router and reflash or update the firmware.
If still wont work then it will be hardware problem (bad memory).
Oct 03, 2008 | 2wire 2700HG-B Router (2700HGB)
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
Lose DSL connection a lot!
Unplug you dsl and your router. Wait 20 seconds. Plug your modem back in. Wait until the DSL light turns green. Then turn your router on.
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
1,319 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
