All the bolts removed then all thats holding it is the adjustable tube in on the lower fitting ,put a bar in and try moving it then it will move as on the lower fitting with the long bolt is a tube in the alternator housing bracket and this is pulled or pushed out to make contact with the support bracket .Check you havent got three bolts holding it as some vehicles have two bolts on the bottom bracket or one long one
SOURCE: can't get the alternator out!!
You can remove the fan clutch to add additional space. 1.8 T or V6? On 1.8 T remove the turbo hose. You have 2 types of fan clutches. Usually a big nut on the fan which must be removed by blocking the pulley or holding it and turning the big nut as to tighten it (opposite threads.) Usually seized on a little heat is needed on the nut just being careful not to heat the clutch and damage it. Other model have an 8 mm allen in the back depending on the fan clutch. With this advanced you'll have more space to move the fan a little. If you have to remove the front it's really not as bad as you think. About 1/2 hr it'll be advanced. You don't have to take it all off just advance it without removing the rad hoses or a/c or radiator.
SOURCE: VW passat 2002 tdi- Alternator
you have to lift engine a bit to make clearance. take engine mounts loose or contact vw dealer and talk to one of there techs
SOURCE: bad missing in motor on 2001vw beetle
If it is a 1.8 turbo the plugs are under the coil packs on top of the engine. A regular spark plug wrench will fit them. They are down in the block about six inches. They are easy to change. I changed them in about 30 min. The coil packs are held on by 2 torx screws.
SOURCE: 2001 vw alternator on the fritz
turn off radio to keep from losing code.remove negative battery cable.disconnect wires from alternator .mark wires with tape to be sure they go back in the same place.loosen belt tension remove belt .if you have VR6-AAA-ENGINE remove the belt tensionsr from cylinder head .remove alternator adjustment bolt followed by pivot bolts .slowly lift alternator from bracket.smile take a deep breath dont need many tools.all you need is the basic tools. basic 3/8 socket set and open -close box end wrenches 13 up to 18 metrics.
Install or connect the following:
