Question about Roper RAX4232KQ Top Load Washer
Will not rinse
It will wash the load but when the control goes to spin it just stops and I will turn the knob to rinse and is still will not do anything, but if I put it on spin it will spin.
  • 22 Answers
Check thet the rinse hold button is not on or it could be one of the water valve check the filter as well
Posted on Nov 13, 2008
I have a timer control problem with a LSR5233EQ0. I need to press down on the timer knob to keep the machine working. It will agitate but with stop when it goes to spin.
Possible that the timer contacts are not giving connectivity when it moves forward into the cycle and so there is no control to the motor drive causing it act irregularly.
The suspect seems to be the timer module.
Jul 29, 2012 | Washing Machines
Model: 110.29822800 Cycle Control knob seems loose. When turn knob clockwise and pull knob, it seems like out of position. For example, I set at Normal, rinse and pull knob. It rinse a minute or two and...
Could be one of two things. The knob or the timer. Both knobs and the timer through sears parts direct are under 100 probably with shipping. If the knob that you pull out and push in does not feel sloppy when you turn it then i would guess timer is faulty.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
When washer is done agitating, the cycle simply just stops. No noise at all. just stops. Doesn't drain or spin.
that would be your lid switch,,, assuming it is a top load,, if it is turn the knob just past the rinse cycle and see if it starts agitating again, you may have to play around with the knob to get it in the right spot,, if it does then replace your lid switch,, if it goes out it will not let it spin or drain
Jan 26, 2011 | Washing Machines
When washer done rinse cycle lights flash and washer stops doesn't rinse and spin
Hello
Try reseting the machine.Unplug power for 60 seconds.
Plug back in,then turn knob to reset.Then try another load of wash or finish the one that is stuck before rince cycle.
It is possible the control timer is going bad.
Aug 29, 2010 | GE Washing Machines
Rise and spin
While the machine is operating take the timer knob and wiggle it around. If the machine cuts out momentarily then the timer is bad. If not then I would check out the lid switch to see if it is affecting the rinse and spin cycle.
Eric
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
After a load of laundry is washed the clothes are still soaked. What would cause this?
Hello brendalee. The unit is not performing the rinse cycle. I can suggest you VERY SLOWLY turn the control knob a click or two and see if the water for the rinse cycle starts when the unit stops after the wash cycle. Unit should fill, wash again, and spin. If the machine never spins I will need Mgfr, model, & serial # to assist you futher if you wish to use some hand tools and repair the unit. Good Luck.
Oct 08, 2008 | Washing Machines
Wash goes silent at the rinse and spin cycle
if the wash water isn't draining you have a bad lid switch back out the two screws at the bottom of the control panel in the back pull the control panel forward tilt it back on its hinges on the body of the washer you will see a connector with three wires grey green purple make sure the knob is in disconnect the connector and put a jumper wire from gray to purple where it goes to the control panel pull out the knob and see what happens
Mar 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAX4232KQ Top Load Washer Logo
64 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
