Question about RCA 27V530T 27" TV
VERTICAL PROBLEM ITS A RCA 27V512T ONLY HAVE 1/2 PICTURE IS LIKE VERTICAL BUT I DONT KNOW MAY BE THE EPROM NEED TO REPLACED THANKS FOR HELP ME
3 Suggested Answers
BMW Rider
  • 232 Answers
SOURCE: Rca 24V511T
take123, problem is with vertical circuit not eprom, could be bad capacitor supporting the IC or the IC itself is bad, that type of problem needs a tech because once it`s fixed you will probably have to go into the service menu and re-adjust the vertical positioning, this of course will require the info in the service manual which you can`t easily obtain, questions? e-mail me back, BMW Rider
Posted on Dec 20, 2007
  • 121 Answers
SOURCE: PARAMETERS FOR RCA
hold menue button in. push power once vol up once.vol up to76 ch to po1 po3  have fun.
Posted on Dec 03, 2008
gopakumarg43
  • 69914 Answers
SOURCE: How do I turn off
Hello
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
HAPPY NEW YEAR
Posted on Dec 31, 2010
Cant turn stereo on 27v512t stuck on mono
http://www.manualslib.com/manual/138691/Rca-27v512t.html
manual has info needed
Enjoy!!!
Feb 03, 2013 | RCA Televison & Video
RCA TV Model F36650 Verticle
There are defective components in the vertical circuit. If you can solder and are comfortable working inside the set (there are dangerous high voltages present even when unplugged), you can fix this. Let me know and I'll provide additional details and instructions.
Dan
Dec 02, 2008 | Televison & Video
RCA picture problem
Hi
This is vertical issue, your unit have problem in vertical section. this is Changed Value resistor, this needs to replaced a new one.
Thanks!
Nov 28, 2008 | Televison & Video
RCA TV Model F36650
bad electrolytics vert circuit.
Nov 20, 2008 | RCA F36650 36" TV
PARAMETERS FOR RCA
Nov 13, 2008 | RCA 27V530T 27" TV
RCA p60752eb no picture porblem
most likely its a vertical deflection issue, try soldering the vertical otput IC as that may just need to be resolderd, if that doesnt help try replacing the Vertical output.
Sep 16, 2008 | RCA P60828 TV
Toshiba Problem
Look, replace all capacitors around horizontal transistor, if dont work, adjust eprom.
May 12, 2008 | Toshiba CF36H50 36" TV
Rca 24V511T
Nov 30, 2007 | RCA F36650 36" TV
TV dropped
That's still repairable here some tips need to consider as follow:
1) Intermittent loss of syncronisation, both horizontal and vertical
The surface mounted power transistor on the teletext module requires resoldering. As there is evidence of scorching on the board the use of a more substantial component would be indicated perhaps with small heatsink
2) Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
3) Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
4) Problems with screen size
Look out for 2 x 2.2uF electrolytics (sometimes red in color)
5) Vertical height oversize
The eprom was found to be faulty (nvm)
Please let me know any update.
Nov 28, 2007 | RCA F27676BC TV
RCA 27V530T 27" TV Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
