To free hard disk space
Sir,
I have Dell XPS 1210 laptop in that C: drive has a capacity of 100 GB; it shows 62 GB occupied and 38 GB is free. But after exploring C: drive and selecting all files & directory including hidden folders (control A), checked property then it shows only 32 GB occupied. I wanted to know where the 30 GB occupied and how to clear the space.
Regards
    Problem Solver:
100 gb is in single partition, I tried defragment but no luck. I have window Vista is it differs? because I noticed that after restoring the restore point I lost almost 10 GB space. Any solution for this?
thank reply
Posted on Nov 14, 2008
    Genius:
  • 1,605 Answers
Is the 100Gb divided into 2 partition?
since you have done the show all folder and files. and nothing else show up. you can do a defreg. to compress the drive. you may have lots of fragmented files. (that account for the lost space).
Posted on Nov 13, 2008
Xps 400 6.0 gb/s hard drive upgrade wont work
Did you initialize the drive in control panel, administrative tools, computer management, disk storage?
Mar 03, 2014 | Dell XPS 400 PC Desktop
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
230 gb drive with 100gb used and only 70gb of free space showing
please check if the files are hidden. just go to the explorer -> tools -> folder option -> view tab -> then on the Advance Settings click the Show Hidden Files and Folders. then try to navigate your external hard drive.
Jul 02, 2010 | Western Digital WD Passport 250GB Portable...
I have a problem with my Local Disk C .
It sounds like you formatted the Utility Partition of the HDD and loaded the OS to that partition. Check disk Management, see if you have both a C: and D: listed for hard drives. If you do, that is the likely answer.
If disk management shows only 1 HDD and a lot of unpartitioned space, then you made a disk partitioning error and will need to remove and repartition the drive then reinstall
Dec 18, 2009 | Dell Computers & Internet
My disk will not allow me to add doc. It says there is not enough free space. But I've only got a few docs on it.
Insert it in a USB 2.0 port. Wait until computer recognizes it. Open the computer explorer (Click on My computer icon on desktop). Right click the SanDisk drive icon and select Properties. You should be able to see a pie chart of the contents of the drive (free space/used space). You will also see the total capacity.
It is not the number of documents that counts, but the total weight (number of MB of the lot). A single movie may occupy 4 GB of disk space.
Hope it helps.
Oct 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Laptop should have 80gb of hard drive but only shows 62gb
The rest of size might have been used for system file ..you can see it by
goto > tools>folder option >uncheck hide system file ...
Jul 18, 2009 | Computers & Internet
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Disk space problem in hp dv6000 series
Hi
Probably ur system is infected by a rootkit.Search on the net for antiviruses that find out rootkits in the system. Avg 8.0 or Panda 08 can detect rootkits also.
B4 that just deactivate system restore and see whether this solves ur problem.
I had this problem once and this was due to rootkits, but i hav seen sum systems where its due to system restore.
Jun 09, 2008 | HP Pavilion dv6000z Notebook
HARD DISK CAPACITY PROBLEM
When your hard disk capacity says 320, that does not mean 320 GB fo free space, Total capacity is 320 GB, from this space required for the partition table, boot sector, etc will be taken, Dont worry only the available free space will be shown.
This is not a problem, so dont worry.
Dont forget to rate me fixya
Jan 10, 2008 | Computers & Internet
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
