Question about Orange SPV C500 Pocket PC
Phone not used for a while-please give me advice on battery issues
Do you know how I can test a cell phone battery to see if it is stuffed or not? I have been given a spv c500 that was working when I was given it a few months ago ? but I didn?t have a charger for it so it went flat. Its been sitting flat for a while and im wondering if its stuffed the battery? I bought a charger for it but it doesn?t light up or do anything. Would a cell phone work if the battery is stuffed but the phone was connected to the mains? Not sure if a reset will fix.
  • Rosemary Young Nov 16, 2006
    I have tried that-it has been plugged in for hours. Do you have a ny more ideas on whether it is the battery or not? or is the chargere faulty?
    President:
  • 2,961 Answers
Sometimes if the battery has gone well below it's re charge state, it won't even work when plugged in until it has got some charge to it.
Posted on Nov 16, 2006
I can't get my phone to work.My battery is good and charged but the phone still doesn't work. It is new.
Kathryn, contact the shop/company from which you purchased it... Customer Support is I imagine the best place to start...
May 15, 2016 | Consumer Cellular Doro 410 Large Text Flip...
Hi, my nokia 5530 is not charging at all.... at first it started charging but after a while it stopped..... but when i tried turning on the cell, it didn't and it is not recharging anymore.
Welcome to Fixya.
Here's what I recommend for you to try out:
  • Remove the battery
  • Press and hold down on "Power" for at least 10 seconds
  • Return the battery in place and try to charge it
Similarly, here are some other options :
  • Try another known good working power socket
  • Seek another known good charger and try it out
  • Replace the battery
If these would still not resolve your issue, then the phone needs to be serviced by a certified technician. Please note that these are the only DIY procedure that I can give.
Thanks for using Fixya.
Jun 05, 2011 | Cell Phones
My LG KF 750 doesn't turn on. when i press the turn on button the welcome screen of LG come and blinking..is this due to software problem.where can i fix it.please help me
Hi, There are different possible things that can cause Your LG cell phone to malfunction the way it does. Possible reasons below:
The battery,,
The Phone memory.
The battery of the phone can be the problem.How Sometimes when a phone cell phone battery is weak and It might not be able to power up the phone. You can test the battery by using another battery to test on the phone,or you can test the battery by using the battery on another phone to test if the battery is still working properly.
The phone memory might also be the problem. When an application is being downloaded on a cell phone or being Transfered to another cell phone through Data cable or Blue tooth, it is easy for VIRUS to affect the phone and when a VIRUS affects a cell phone,the cell phone will malfunction.
To fix a malfunctioning phone like a VIRUS infected phone,you will need to flash the phone memory of the phone.
When you flash a cell phones memory,it will restore back the phone to it default state.
You can use the below links to know more on how to flash a phone.
www.hubpages.com/hub/How-to-Flash-your-cell-phone.
Good luck to You.......
Feb 01, 2011 | LG Secret ? KF750 Cellular Phone
My SGH-g600 is going off regulary. once it goes off, i need to connect an adapter and start charging it.
Hi, In most cases like this, there are two major problem that can make a cell phone to act that way.
Which are:
The batter of the phone,
And the memory of the phone.
When a battery of a cell phone does not power up a phone for too long,possible problem might be the cell inside the battery that powers on a phone is dead and can keep the phone on for long period of time...
You will need test for the battery life by using another battery to power the phone on, or you can get a friends phone battery to test your phone.
Also the memory of the phone can be the issue too. When an application is downloaded on a phone or data was transfered through blue tooth or data cable transfer,in the process of the transfer, it might have contacted VIRUS and when VIRUS affects a cell phone,The cell phone malfunctions..
To rectify the malfunctioning of the cell phone,you will need to Flash the phone memory.
Flashing a phone memory will restore back the phone to a default state.
You can use the below link to know more about flashing of phone...
Good luck to you.
Feb 01, 2011 | Samsung SGH-G600 Cellular Phone
I need to find a manual to know how to change the batteries in this phone
First of all, it will be advice able for you to write in the name of the type of phone you want to change the batteries. If it is clearly stated, I will so happy to be f service to you. Please kindly state the type of phone you want to change the batteries. By stating the name of the phone and the model for example nokia E71 or samsung corby etc.
Also before replacing a battery of a phone, be sure to have tested other components that are related to the power before concluding it is the battery that needs replacements. Components to also check are the charger and the phones connection port by trying out other devices on them, like trying the charger on another device and trying another charger on the phone so as to know if the problem is from the charger or the connection ports respectively.
Would be happy to be of service to you. So please state the type of phone and model number.
Hope this was helpful. Thanks for using fixya.
Jan 26, 2011 | Cell Phones
My phone dies after 10 mins of use is it my phone or battery?
It could be either of those. If you've had this phone for a while and it's gone through a lot of charging cycles, I'd say try another battery (one you know is good, if possible) and see if the problem continues. A worn-out battery can take a charge but not store enough energy to give good use. It's also possible that something in the phone has gone bad and is drawing excess current and draining the battery, but I'd say that's unlikely. Something drawing enough current to be an issue would probably cause heating you would feel.
So try another battery first if you can, or check with your service provider or a phone store to see they can test the battery.
Dec 02, 2010 | LG Vu CU920 Cellular Phone
My samsung impression overheats and drains my battery within minutes of use. i will have it fully charged. if i dont use it it will be dead in an hr or two. i just used it and i was on the phone for like...
There is some issue with your battery. Before you replace it ... please contact your carrier for advice.
Thanks for your interest in FixYa.com; please remember to evaluate this response. Thanks
Jul 05, 2010 | Samsung SGH-A877 Impression Cell Phone
Switched off suddenly
you have a loose battery connection. try stuffing a piece of paper on the end of the battery. next,. you'll open up and see the pin where the connection of the battery is. try pulling out the connection slightly and you'll be able to have the battery connected to the device.
then try knocking it back to test it. lol..
but the rest should be fine. mine had the same issue yrs back. but now its working fine.
rate me if this is helpful.
thanks..
Sep 22, 2009 | Sony Ericsson K550i Cellular Phone
V600i will not turn on ...
sounds like you may have a battery issue, try a new battery first, after that, you might as well get a new phone, since repairs are going to cost more than the phone does.
Oct 28, 2007 | Sony Ericsson V600i Cellular Phone
Orange SPV C500 Pocket PC Logo
113 people viewed this question
Top Orange Computers & Internet Experts
ismael castillo
Andrew Taylor
Andrew Taylor
Vladimir Frolov
Are you an Orange Computer and Internet Expert? Answer questions, earn points and help others
