Home | Sharp | -COPIERS - AR-5316 Advanced Digital Ima... | Sharp sf 2114 too muc...
Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
Problem for Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
Sharp sf 2114 too much toner on copies
By nancywebboli on Nov 13, 2008
Each copy is streaked with extra toner. I can wipe down the bar, or insert a copier sheet to clean it, but it comes back quickly
Solution #1
posted on Nov 14, 2008
Not Rated)
lbcoaster
Rank: Guru  Sharp Expert
Rating: 93%, 152 votes
Sound like you need to have the developer, drum and drum blade replaced, you might want to have a tech look at this.
Hope that helps.
Lbcoaster
Was this helpful?
Yes
No
Popular Solutions for Sharp -COPIERS - AR-5316
Questions and Unsolved Problems for Sharp -COPIERS - AR-5316
Do you recommend Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier?
Answer
Answer
im facing one problem if e 004 service code for canon 7161 what is the solution?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp -COPIERS - AR-5316...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1501
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
