Question about ASUS Eee 4G Notebook
ASUS notebook F3S series wireless network adapter problem
I have a continuous problem where my wireless network adapter keeps dropping out requiring a reboot to reconnect to the internet.
Is there a reason why this is happening? How can I fix it so it doesnt happen so often.
My System specs:
AUSUS notebook F3S series
32 bit operating system
OS Vista Business
  • blerin Dec 20, 2008
    I have an Asus F3 laptop nad the wireless keeps dropping out and I have to reboot. Last night it went out all together and the computer can not "see" any wireless networks.
Asus pce-n13 802.11b/g/n adapter keeps dropping the link to the router. signal levels are ok. It is as if it keeps resynchronizing
Try to check if there are any other wireless networks in the same channel as yours. Your home wireless network should be in the less crowded channel from 1, 6 or 11.
May 03, 2011 | ASUS Computers & Internet
My Asus M50Vm notebook is no longer recognizing my wireless network. I have gone to the website and updated my drivers, but I still cannot connect wirelessly. I also checked to make sure the wireless...
I'm assuming by 'no longer recognizing my wireless network' that at one point in time your notebook was connecting without problem, but now for whatever reason it's not connecting because your Wireless Network (SSID) is not showing up when your notebook scans for networks.
If you remember what your Network's SSID is called, I would try setting your wifi card to connect to it manually vs connecting to 'any' SSID in the area. Wifi networks won't show up when you scan for them if they're set to not broadcast their SSID's.
That is the most mundane assumption I can make as to what's wrong. There are a bunch of other problems that could cause this, but I'd try this solution first.
Apr 22, 2010 | ASUS Wireless (90-c1i010-00xay)
Drops connection often
Check Firewall and AV settings. Optimize the browser
Apr 03, 2010 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Can not get wireless connection on asus notebook
Try resetting the network adapter.
On the bottom right hand side of the desktop you will see the wireless icon, right click on that ans click on troubleshoot problems. This will reset the adapter and assign an IP address for your your PC.
When its done try to connect to the internet.
If this advice does not help please post back.
Good luck.
Jan 11, 2010 | ASUS m6n Notebook
My brand New Asus laptop keeps dropping off wireless network
try it on another wireless connection and see how it works. Belkin routers are usually not the best, that's why they are so cheap
If the prob persist on another wireless network than contact ASUS technical support
Sep 09, 2009 | ASUS Eee 4G Notebook
Trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
The F10 F11 F12 sound keys not working on my Asus F3S os Vista
I don't know how to do to help you, - 2 solutions:
1. go here and specify if you pc is a F3Sc - F3Se - F3Sv and download the drivers. ( don't use driver detect, that will cost you....)
http://www.drivershq.com/Drivers/ASUS/F3-Series/13236/24543/Models.aspx
2. Reinstall, to WinXP, with that you get a computer leaving the table, with the speed you get on XP, but that's up to you. XP Drivers here:
http://usa.asus.com/search.aspx?searchitem=1&searchkey=F3S
- again, choos your model, and then your OS ie WinXP, - they are all there, - go on you asus.
Personally, I would not hesitate to install XP, but don't mind me, I have been working (full time as an adminisrator) with Server2003 and WinXP for years.
/Teis -> don forget to vote :-)
Dec 08, 2008 | Computers & Internet
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
ASUS Eee 4G Notebook Logo
1,670 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
