Question about Acer Aspire 5610-4648 Notebook
The word ''Acers'' apperas on the screen and its not loading
On the bottom left hand corner it says press F2 to enter set up. I do that and it just sits there and not load up. I guess it froze. Everytime I try to turn it back on, same thing again. Acer on the screen and its not loading. Theres a blue bar across showing that its going to load but its not loading.
  • Acer Master
  • 4,806 Answers
If you can find the motherboard battery, remove it and leave it out for around 2 mins, this should reset the CMOS (date,time, settings etc) make sure the laptop battery is out and its not plugged into the mains, the other way is to flash the bios by downloading the latest bios version for you machine providing that it boots to windows, the only other option is to flash via floppy with AC power on!!! NOT RECOMENDED as if it goes wrong your pc will be permanantly dead
good luck
Posted on Nov 13, 2008
HOW to tget to bios acer aspire AST180-ED400A
Immediately after pressing the power up button, start repeatedly pressing F2 while the Acer logo is displaying. The Bios setup screen should appear. If you press F2 too soon, the keyboard may not have initialized yet. If you press it too late, Windows will proceed to launch. Press it once, wait a second, press, it again, wait another second, and repeat this while the Acer logo is displaying until you see the bios setup screen.
This is standard approach with most Acers. That said, some laptops may defer to either Ff being the key to press or CTRL+ALT+EXC. Such would be entered as the above mentioned F2. Your Aspire appears to be a desktop and I suspect F2 will suffice.
Feb 19, 2015 | Acer Computers & Internet
Black screen flashing dash top left corner. ....wont reboot after system restore
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 03, 2012 | Computers & Internet
When I turn my laptop on it comes up with a single line in the top left hand corner. What can it be
Does it not go further than that? Does the OS load?
If not are you able to access the BIOS page? Accessable by usually pressing "del" or F2 on the splash screen on start-up.
Jan 09, 2011 | Computers & Internet
My dell laptop wont turn on the screen is black with a little line blinking in the upper left hand corner
When your computer is booting up you have the option to press F2 or F12.
PRESS F2 -Set Up
When your in the Set Up go down to Boot Device Configuration(BDC)
Now under Hard Disk Boot Priority
You Will see first boot device
second
third
and boot other device
For the first boot device select "HARD DISK"
After you have made the first boot device hard disk press F10 to SAVE and RESTART
Dec 06, 2010 | Dell C500 Notebook
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
Grey screen with white line on my laptop
I took the battery out then put it back in and it works fine now.
Apr 28, 2009 | Computers & Internet
I have a toshiba a135-s2376 laptop i first booted this computer 45 mins ago it would not i waited and then f2 f12,at lower left hand corner appeared it just sat did nothing so i hit f2 it took awhile for...
press F12 , F2 or DEL key for enter in bios setup.
detect your harddisk .if not then try to disable sata and save settings then start the pc.
also u can try to put awa CMOS cell for 15 minutes to reset your bios settings it is in back side of your laptop.
Oct 14, 2008 | Computers & Internet
Conflict between on board graphics and new graphic card
to get into BIOS tou have to press a key when computer starts and i just finding hard drives
key to press is either
1) del 2) f2 3) f10 most computers use these keys for BIOS
down the lower left hand corner od screen will be whar key to press
eg press del to enter BIOS
whenin BIOS you will have a list of pages to go open the one that has video in it use down key to get to it
on left hand of screen will tell you how to change it.when changed press esc key keep pressing esc until it come to do you want to save changes press y and enter computer will reboot
Remeber what you did incase you have to undo it
please post comment if this was helpful
Jul 27, 2008 | MSI RC410M-L Motherboard
Acer aspire 5715z/5315, turned laptop on took time to load up wasnt responding,restarded laptop then it wouldnt restart then i turned it of manually, turned it back on,screen acer back ground in the bottom...
Reboot your system-press and hold F8 until you get a list of options-select Safe Mode-enter.Your system will run in Safe Mode,giving you a dropdown list as it progresses-check where it stops.In this way you can establish wether you have a corrupted or incompatible driver and which {Graphic ie} stop the system.You will have to reload the OS to solve the problem.If you cannot even boot into Safe Mode,your drive very likely crashed.Happy landing.
Jul 22, 2008 | Acer Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
