Question about SanDisk Sansa e250 MP3 Player
Sansa 260 how do i get it into recovery mode
  • 80 Answers
This is how to do it READ EVERYTHING DONT SKIP THING
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Retail/Default.aspx?CatID=1449
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully.
Step 5:
Enjoy using your Sansa E260, just like I do. (I love this player)
sorry for so much writing it pays off read this to
) Unzip the downloaded zip file and extract the file pp5022.mi4
2) On your Rhapsody device, go to "Settings" -> "Mode" then select "Rhapsody"
3) With the data cable, plug the USB connector to the USB port on the PC, verify “Connected” is shown on the e200R display
4)On the PC, Check for device “Sansa e200 (E:)” under My Computer.
NOTE: the actual drive letter might be different
5) Drag and Drop pp5022.mi4 from your PC to the root folder of E: drive.
NOTE: Do NOT drop it to “Sansa e200R Rhapsody” device which is the MicroSD card slot
6) Unplug your Rhapsody device.
7) Your Rhapsody device will restart and perform a firmware upgrade and restart again.
When done, go to main menu “Settings” -> “Info” and verify the current version number.
enjoy
Posted on Nov 14, 2008
The screen is lite but not playing music won't turn on or off , what to do ?
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
Recovery Mode also resets system settings when unplugged...
Jul 01, 2010 | SanDisk Sansa e250 MP3 Player
My Sansa e200 series is stuck on the splash screen and would not response on any or cannot be recognized by computer. Please assist
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring ) and put the back on.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard thIs should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize IF not try a laptop.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
Reset All
will be gone.
Jun 27, 2010 | SanDisk Sansa e250 MP3 Player
Can't use
Reset All
will be gone.
My computer doesn't recognise my sansa 260.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard ths should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
My sansa e260 turns on and shows the sanddisk page(balck and whit) then it changes and says load main image failled switch to recovery mode. so i do that and it doesnt do anything when i do,, what is wrong...
Reset All
will be gone.
My e260 gets to the refresh database screen and starts to fade out to a white screeen and restarts
1: RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
2: Reset All
will be gone.
3: Recovery Mode also resets system settings when unplugged... lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software
Apr 05, 2010 | SanDisk Sansa e260 MP3 Player
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
How do I UNDELETE a voice recording I deleted on my sansa e250?
sorry. but i'm pretty sure you can't undelete something. Be careful about what you delete next time
Feb 26, 2009 | SanDisk Sansa e250 MP3 Player
Sansa 260 4GB
Will Windows read it as a flash drive?
If so, find a file recovery program like undelete or something, use it to restore your files, then turn on the sansa, then select format( if it is a view) and it will delete all your songs
Oct 25, 2008 | SanDisk Sansa e260 MP3 Player
PROBLEM SANSA E 260
1.to switch the device to recovery mode turn the hold switch to the locked position. hold in the record button and plug the device in. do not let go of the record button ubtill you see a 16MB partition show up
2.when you got the 16 partition copy a new main image file into it
here are soem diffrent types of them :p
AMERICAS - 01.02.23a for Americas
EUROPE (No FM) - 01.02.23e for Europe without FM
EUROPE (FM) - 01.02.23f for Europe with FM
PACIFIC - 01.02.23p for Pacific
download from : http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10356
when you downloaded and copyed the main file you should make just an emty doc named : sansa.fmt
no more in that one just move that doc to recovery disk to
hopes it works... a tips are this site http://forums.sandisk.com/sansa/board?board.id=e200
they got many good guids for stuffs like this
Jan 11, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
163 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
