Question about Hoover Washing Machines
I have a Hoover Washer Dryer HNWL 7166. The Delay Start indicator is coming on MOST of the time a couple of minutes after starting the programme (whether it be wash or dry mode) cutting off the programme. Perseverence usually results in the programme completing its' cycle but, it can take a while which is infuriating. This just started after the guarantee was up.
11 LED flashes indicates either a wiring fault or I'm afraid the main board has gone (Hoover Engineer required).
Posted on Nov 14, 2008
How do i change a drum paddle in my hoover HNWL 7166 washer dryer
There's a screw holding each paddle in place, as well as the lugs on the paddle. You can get to the screw by removing the drain hose from the bottom on the drum, and the paddle will then be free to slide out
Jul 09, 2011 | Washing Machines
Washer keeps stopping and is still full of water and the delay start button is flashing
Drain pump is either blocked or failed. Check the pump filter which should be at the front right of t he bottom of the machine. If this is clear, you may have to remove the pump to get debris out of the pump housing. Ly the drain hose on the ground to drain the machine first and unplug before going at it.
Dec 08, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
I have a hoover hnwl 6136, and it's not drying properly. Presume I need to clean the filter but I cant find it?! Help?!
I have the same problem. Do you have a manual for this washing machine/dryer (HOOVER HNWL 6136)? I looked everywhere for a manual and I couldnt find one. If you can email it to lettings@fesamuels.com it will he much appreciated.
Oct 07, 2009 | Hoover Nextra HNWL 3166 Front Load Washer...
We are looking for a Programme Selector for a Hoover Nextra HNWL 3136
hi there my best advice is phone gias in rochdale go to gias website for number when you ring tell them you repair washing machine so you get a trade price
Jun 23, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Program don't start, flashing ligths (start and "delay start" button) for 5 times.
What does the error code mean do you have any idea Is it mentioned in the Hand book. At any rate logic suggests a watewr supply problem that the first thing a washing machine needs - water. So a tap not turned on a Kinked hose An inlet valve solenoid failure- Three things for you to check
Jul 31, 2007 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
253 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
