Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Printer head what does it look like?
    Sergeant:
  • 276 Answers
It is a plastic box of square/rectangle shape with a space in it to install the cartridges.have a cable wire connected to its back which goes into main board.and then it starts functioning.
Posted on Nov 18, 2008
My printer is saying printer head error,how to resolve it
I would try to remove the printer head and clean all the contacts, on the head and in the printer. If the error keeps comp back, you could try to put in a new printer head to check if that resolves the problem. If not, normal A4 printers cost the same as a new printer head. Perhaps buy a new printer?
Jan 12, 2015 | Office Equipment & Supplies
Printing will not align
Reinsert printer head
Problems with the printer head of printers might be because the printer head is not secure in its position. The problem would cause the printer head to wobble and produce bad prints. All printer users having problems with printer head are advised to check the seating or the printer head, remove it and then reinsert the printer head if it is not found properly seated.
Clean printer head:
As your printer is used, the printer head might get dust or dirt settlement from the paper being fed into the printer. Dirt settlement would cause printer to produce very poor print quality and such issues can be resolved by carefully removing the printer head and cleaning it with a printer head cleaning solution. However, care must be taken when cleaning the printer head and replacing it back as any damage to the printer head during the cleaning process would affect the functioning of the printer. Brother Printer Support
Oct 16, 2012 | Brother Ink for Mfc-885cw, Lc-1000
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Jan 08, 2012 | HP DESIGNJET T1120 44 Printer
I only have black ink i cant print
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAwMzEwNjAy&cmp=ABR&lang=EN
This is a PDF( Portable document file) of the User Getting Started Manual from canon. you need a pdf reader to view it.
I think that your jets are clogged and you may need to clean the heads which is show in the document or checked to see if the heads are stopped up and hard. they may need to be manually cleaned.
Steps for Manually Cleaning the Printer Head Step 1 - Remove the ink tanks and printer head. Remove the ink tanks from the printer head (tank holder) and seal them in a zip lock or other sealable plastic bag. Set them aside, preferably propped upright.
Next remove the printer head (it snaps out). NOTE: You may want to wear latex gloves to help keep ink off your hands.
Step 2 - Soak the printer head. There are multiple suggestions on ways to clean the printer head and all have some variation on the following:
  • Get a small, shallow pan and lay down a layer or two of paper towels in the bottom of the container to protect the printer head circuitry from contact damage.
  • Heat up (via microwave) enough purified/bottled water to cover the paper towels. You can also use a 50/50 mixture of ammonia and distilled water (about a pint will do). Heat the mixture in the microwave for about a minute or so - it should NOT be boiling.
  • Slowly pour the water or mixture over the paper towels so that you have approximately 1/2 inch of liquid in the bottom of the pan.
  • Set the printer head into the container on top of the towels. You should see ink 'bleeding' out. Move the print head to several different spots (about a minute each spot) and shake gently. This will dissolve the ink clogs.
  • If the printer head is badly clogged let it soak for 3 to 4 hours or overnight. You can move it slightly to a different spot every hour or so.
Alternative Soak Method:
Mix a 50/50 solution of warm water and Windex and place in a shallow container, enough to cover the base of the printer head and ink ports. Leave for 2 hours while agitating the unit occasionally. Remove from the mix and lightly scrub the base and internal ink ports with an old soft toothbrush. Do not scrub the gold contacts but don't be concerned if they get wet. Return the unit to the mix for another 2 hours and agitate occasionally. Remove and scrub again as before.
Step 3 - Flush the printer head with water.
  • Hold the unit under a softly running warm water tap. Place your finger over the tap to create back pressure to allow you to squirt the water into all crevices of the printer head. You should see the gunk build up flow out. Do this until the water runs clear.
Step 4 - Dry the printer head and replace.
  • Remove the printer head and rinse it thoroughly with distilled water. Shake it dry and set it on folded paper towels to air dry. (Some folks use a hair dryer on a low setting to dry the printer head.)
  • Reinsert the printer head and ink tanks. The printer should automatically do a "Printer Head Alignment." If it doesn't, manually perform "Printer Head Alignment" through the printer's utility. Next run a printer head cleaning cycle or two followed by printing a nozzle check pattern to check your progress.
  • Repeat as necessary.
Variations on the Above Steps
  • Soak the printer head in one of the proprietary solutions (Cartridge Flush, Magic Inkjet Flush) specifically designed to clear print heads. Soak the print head for about 10 minutes to overnight depending on the degree of blockage. It has also been reported that you can clean the print head with an electronic toothbrush and cleaning solution for about 20 seconds with excellent results.
  • Use a full eye dropper to flush alcohol through the appropriate ink 'hole(s)' that show inside the printer head unit. Don't rush this: do a drop at a time or you might flood the inside of the unit.
  • Purchase an ultrasonic cleaner. Wash the printer head under the water tap to remove excess ink. Load the cleaner with the printer head and water so that the printer head rests lengthways in the cleaner with the electrical contact surface visible. Repeat the cleaning program a few times, using clean water in each program.
Preventive Maintenance
It's a good idea to regularly conduct preventive maintenance on your inkjet printer to prevent it from developing clogged printer heads. Printer heads become blocked for a number of reasons, but the most common is simply that the ink cartridge and the printer head have dried out. Never let the printer stand with an empty cartridge. Either fit a fresh one, or seal the print head unit in a plastic bag with a few drops of water for humidity. Since print heads become clogged when not used for long periods of time, regularly print a page or two to keep the print heads clear. Some experts say that it is better to print one colorful page a week than to run a printer cleaning cycle, because doing so uses a lot less ink. Ideally, printer cleaning cycles should be started once a week to prevent the printer head from getting clogged.
There are other more ink-efficient ways to be able to clean printer heads that will prevent their clogging just as effectively as running the printer's cleaning cycle:
  • Brush the printer heads with Q-tips soaked in water. Sources vary on whether alcohol would be more effective than water, but in the opinion of some printer experts alcohol can be harmful to printer heads and should thus be avoided.
  • Buy a cleaning kit and use it regularly on your printer. A typical cleaning kit usually has a tube of ammonia that you can spray on the printer head to remove dried ink.
  • Covering the printer when not in use to keep it free from dirt and debris also helps prevent the printer heads from getting clogged.
Follow these step and you'll find you problem resolved.
Sep 14, 2011 | Canon PIXMA MX340 Wireless Office...
How do i clean the head of the canon ip90v printer?
Jul 16, 2010 | Canon PIXMA iP90v Printer
Printer
Maybe you mistyped? Is it 'head or 'header'. I believe it is head you want to say. In that case your printer requires a new print-head to be installed.
Your printer has separate ink tanks and heads for printing. The head has a limited life although it works for along time.
The printer should indicated which color head needs to be installed. Try cleaning the head with the printer software first.
You can purchase the head of that color (or colors if more than one) and follow the install procedure in the printer manual.
If you also want head installation instructions, please take some time to post it as a separate question. I will try to give complete instructions.
Oct 12, 2009 | Canon I900D InkJet Photo Printer
Canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Mar 10, 2009 | Canon Office Equipment & Supplies
Change printhead in 5500
To change the printer head on the Kodak 5500 AIO printer, you will need to do the following:
To remove the old printer head,
  1. Power on the printer.
  2. Lift up the lid to expose the printer head.
  3. Once the printer head moves to the middle, where you can get at it, then unplug the power cord to the printer.
  4. Remove the ink cartridges.
  5. With the printer head now empty, run your finder along the underside of the top of the printer head, all the way to the left side of the printer head.
  6. Push up with your finger where there is some give, and the shroud that holds the printer head will release the head.
To install the new head,
  1. Simply put it in place, and push forward with your finger on the sticker that shows a finger pushing on a sticker, and you will hear and feel it click into place.
  2. Reload your ink cartridges, close the lid, plug the printer back in and you're done.
Nov 29, 2008 | Kodak 5500 ALL-IN-ONE PRINTER
Print head
Printer head is the main item in a printer .
It use to print some thing in to the paper
Normaly dot matrix printers using printer head . But the other ink jet printers or laser printers doesn't use printer head
Aug 05, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer head not installed
If the printer is a Tally printer, the error code mean that the logic board can not detect the print head.
Check the following
1 Print Head cable connection
2 Bad print Head ( Sure)
3 Bad Logic
Feb 24, 2008 | Office Equipment & Supplies
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
old marine
old marine
