Question about NEC Computers & Internet
I have a lcd 195vxm hooked up to a laptop because the laptop screen failed. It has been working fine for several months, but now it comes on and says "video signal 1 dsub no signal". That is the same message it has always said, but now it just goes back into standby mode (yellow light on power button) and won't stay in active mode. I have rebooted, unplugged for a few minutes, but it hasn't helped.
Go to safe mode and decrease the screen resolution,
if still doesn't help go to safe mode again then go to system restore under system tools, restore back to early good restor point
Posted on Nov 15, 2008
Cut laptop on and off several times. Now screen is black and will not come on. What can I do to make screen come on?
On a Dell laptop, you can run a screen check by holding "D" and pressing power. I dont know about other brands. However, you can tr hooking a screen up to the external video port. if It comes up, then you likely just have a bad LCD screen or perhaps even a bad cable connection. If not, it could be a more severe issue called "no post". A no post issue could be the result of a loose memory chip, or failed battery charger (resulting in dead laptop). If you know the ram is good, and the laptop is taking a charge, then the no post issue could be a bad system board or CPU, which sadly, is far more severe.
Jan 03, 2015 | Computers & Internet
Laptop LCD/Display Problem, Green and Pink Tints???
Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Dec 24, 2013 | Computers & Internet
Hp g72-227wm has a broken lcd screen i have a hp compaq le1711 vga flat screen hooked to my lap top it was doing fine i log off out of windows and shut down the pc when i turn it back on the flat screen...
Check monitor is set to correct input (VGA, DVI, HDMI) if it goes to sleep instantly.
Otherwise screen resolution is set too high. Boot into safe mode by pressing F8 during boot. Login and lower screen resolution.
Oct 03, 2012 | Computers & Internet
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
In your situation, you have the possibility of several different problems.
1. Your "Screen Inverter" is failing.
2. Your screen "LCD Panel" is failing
3. The "Video Controller Chip" soldered permanently to your motherboard is failing.
The first step in troubleshooting these problems would be to take your laptop to a friend's house who is using a desktop computer with a separate external monitor. Hook your laptop up to the external monitor and see if it displays normally on that monitor. If it does, you merely need to replace both the Screen Inverter and LCD Panel of your laptop and you'll be fine.
If, however, your laptop will not display on an exterior monitor, it means that your video controller on your motherboard has failed and you'll have to either get a new motherboard installed or consider replacing your laptop.
I'll be rooting for # 1 or 2.
Kind Regards,
Selk
Apr 29, 2011 | Sony VAIO Notebook
I have a dell studio 1745 laptop that is 13 month old. The display has very fine snow storm on it and there are fine lines going from left to right and slowly moving down the page. The colours are all...
This is due to loose connection which could happen after a period of time between the screen to the laptop.
Solution:
You can use another LCD screen as you secondary screen which you need to hook up to your laptop onto the blue connector (vga connection) or get the laptop screen replaced altogether
Feb 02, 2011 | Dell Studio 17 Notebook
Cannot hook up lcd monitor as a multiple monitor. In Vista i use a vga cable to hook up the hannstar lcd monitor model hn199. when i plug in the lcd my laptop (an acer extenda) screen goes black and the...
Try the "Display Swap" button (usually a Fn key). Some of these have several choices each time they are pressed, e.g. Laptop Display, External Monitor, Both, and NONE!). Hope this helps. Ian.
Sep 17, 2009 | Computers & Internet
Trying to find out if this ACER monitor is under warranty
Your monitor is still under the 3-year warranty. Go to this Acer website https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
to begin the process. Hope this helps.
Jul 09, 2009 | Acer AL2216WBD LCD Monitor
HP Pavilion ZE5300 Video is very dim
I have seen this happen before. If the inverter you installed is not from the exact model HP then the pinouts on the signal cable going to the motherboard are not correct. There are several inverters that use the same connector but are not interchangable. I would get another inverter that is for that model and I bit it will fix your machine.
Buddy
Corporate Computer
Over 21 years repairing computers/printers
Jun 17, 2009 | HP Pavilion dv9000z Notebook
Blub
Sounds like the lcd screen has gone out . Hopefully you still havea warranty on it. But a good way to test if its the lcd screen or the graphics card is to hook it up to a external monitor and see if the pitcure comes up if it does then its the lcd if it doesnt then its the graphics or motherboard itself
Feb 13, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
60 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
