Question about HP Photosmart 945 Digital Camera
HP Camera won't turn on
Fresh batteries and the camera still will not turn on. Any suggestions?
I had the exact same problem. I turned on my HP Photosmart E317 camera and it would light up for one second and then just a blank screen. Here's the tech support site from HP. Try taking out your memory card and then turn it on. That worked for me. I just put the memory card back in and it works fine. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709691&lc=en&cc=de&dlc=de&product=445953&rule=2137&lang=de
Posted on May 22, 2007
3 Suggested Answers
fotomohamed
  • 321 Answers
SOURCE: HP Photosmart 735 Camera lasts 2 minutes with fresh batteries
use NiMH batt.
Posted on Jun 18, 2009
  • 54 Answers
SOURCE: camera won't turn on
I am assuming that the power does not go on or it immediately turns off as it is turned on.
Try the docking station or the 3.3 AC adapter to the camera. Plug that in to live power. If you hear the lens motor (by default the lens is retracted to closed position when plugged to AC power), then the camera is operational. If not, there is power failure with the camera.
If the lens motor work, then try to turn the camera while plugged to AC power. If it turns on, then there is something wrong with the battery or with the chamber. If the camera does not turn on, then check the button board for a bad power switch.
Check the LCD closely under a bright light when you do this test. You may see a faint a flash of display that disappears. I have not figured out what causes this. This would mean that camera power supply is working but nothing is telling for the camera to stay on.
Posted on Dec 10, 2008
Even with new batteries, the camera turns off after a few seconds
Be sure you have real fresh Alkaline batteries or fresh recharched NiMh batteries.
The best rechargeable batteries are the ENELOOP (from Sanyo), these have a very, very low discharge, so after a week the camera still works without the problem of turning off after a few seconds.
Jan 25, 2010 | Konica Minolta DiMAGE S414 Digital Camera
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
Jan 21, 2010 | Kodak Easyshare C813 Digital Camera
My kodak easyshare V1003 camera will not turn on. It worked a few days ago and now it will not charge or turn on. I just bought new batteries and it still will not turn on. Any suggestions on how to fix...
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 09, 2009 | Kodak EasyShare V1003 Digital Camera
My olymous f2-20 has fresh battery and won't turn
The reset is in the setup menu but since you can't turn it on, that's useless. Are you sure the battery is inserted correctly? Try cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol.
Aug 15, 2009 | Olympus FE-20 Digital Camera
Camera eats batteries in 2 minutes!
Sorry to hear that you have problem with the camcorder. It does have few situations with not charging battery based on our repair experience. I would suggest to make sure the battery is fully charged and see how it goes. If there's any battery problem, you should send it to Sanyo for manufacture before the warranty expires. Makes sure send every thing back to Sanyo. Battery problem cannot be solved simply other than bad battery contact situation. -James
Apr 12, 2009 | Sanyo Cameras
This camera has been a great little camerafor a lot of years.
If you've tried fresh batteries and ensured that there is no corrosion inside the battery compartment, then it is a problem that wouldn't be cost effective to fix. Repairs on most camera equipment at any shop run at least $50 and up.
Working used cameras of this model are selling for $20 on eBay, so I'd suggest exploring that option if the first suggestions don't fix the problem
Dec 16, 2008 | Pentax PC-606W 35mm Point and Shoot Camera
Batteries
I had the same problem......I went to the store that i bought the camera from and i bought a kit that contained four rechargable batteries, a battery charger, & it also came with a car cord that goes into your cigarette lighter so you can charge a set in your car. PROBLEM SOLVED for $26.00 + tax.
I take a whole lot of pictures (freelance photographer) and I ALWAYS have one fresh set. As soon as the set in my camera goes low i throw them on the charger and put a fresh set in my camera. By the time the fresh set goes low, the set in the charger is ready.
Sep 07, 2008 | Samsung S630 Digital Camera
My battery for my Casio exilim when charging is just blinking red and doesnt turn on my camera. any suggestions? new battery?
apply new fresh battery from good brand first and try to chrge it-if this does not work good the problem in charger itself.
Mar 05, 2008 | Cameras
ClickSmart 510 Will Not Be Turned On
make sure the terminals the batterys go into arent dirty, thats usually one of the main reasons a camera wont function. hopefully it works out, good luck
Aug 23, 2007 | Logitech ClickSmart 510 Digital Camera
HP Photosmart 945 Digital Camera Logo
193 people viewed this question
Top HP Cameras Experts
Harrie
Fred Sops
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
