Question about Quantum SuperLoader 3 LTO 2 Tape Drive
Quantum superloader not showing in windows device manager
We have an SBS 2003 server with Backup Exec software. The Quantum superloader with LTO2 drive that has worked without fault for the last 4 years packed up a month or so ago. After some experimentation with firmware and drivers, determined it was a hardware error and sent it off to get it fixed (twice!).
Now. The device will not show in Windows device manager at all. We have changed the SCSI cable and SCSI card, tried drivers from Symantec, Quantum and Microsoft. We can get the tape drive itself showing, but with errors, but the medium changer will not pick up at all.
Any suggestions gratefully received!
  • Anonymous Jan 15, 2009
    Very similar issue. Installing the "ValueLoader," robotic driver shows up in RSM but not complete control of loader.
  • 922 Answers
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Posted on Aug 11, 2009
  • 24 Answers
I agree and would add to the solution to look at scsi cable termination issues.  Some devices can be set to self terminate.  But if not, then I would make sure the bus is terminated correctly.  Again, the logical place to start is at the device / scsi controller card level.
I also agree with JaxPlanet, the quantum tape librarys are very cheaply made.  A px502 portal / magazine LTO3 full height unit jammed on me and I powered it down but the picker was crooked.  We took the unit to a non-quantum service shop and it cost $700 to replace a sensor, and clean the unit!
My other unit a superloader 3 LTO4 unit can't be manually taken offline or power cycled like the px502 could through the web interface!
lame.  The units work but... and don't get me started on symantec backup exec 12.x.
Posted on Jan 23, 2010
Quantum superloader 3 drive error type
Hi Ulrike
I suspect that your backup software has "locked" the drive / library from the front panel.
This is why disconnecting / rebooting the library solves the issue.
If you are using backup exec or similar, try going to devices, selecting the library, right click and "unlock" before using the front panel buttons.
You could also use BUEX to do the tape moves for you instead of even touching the front panel.
If you are in the UK and are still having problems then click the link below and we will do what we can to help.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Mar 10, 2014 | Computers & Internet
Hi, I have a microsoft Win 2003 server sbs at my office, I can' t log in to my server now becoz it shows " windows needs to be activated" and when i click activate it says you are already...
are you using crack version for Windows 2003 SBS. if yes then restart ur server in safe mode, run the crack again. Be sure to have data backup before.
Nov 25, 2010 | Microsoft Windows Server 2003 Standard...
"error starting the service Backup Exec & media service"
This is most likely caused by a change in the user acount password that you created the profile with. Under network select Logon account Managment. in here you will see the accounts that you used to login to the Domain. (AD) Consider setting up separate accounts (backup, etc) for these services & scheduled jobs, rather than using the admin or personal accounts. This way you can still change the admin account password on a regular basis & maintain security, but not have to go the hassle of updating all of these at each change. You may also opt to set these specific accounts so that the passwords do not expire automatically so that you do not have to deal with that scenario.
Jan 21, 2009 | Veritas Backup Exec 10 for Windows Servers...
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
Quantum ATL SuperLoader
If you cannot physically load a tape into the drive it is a hardware problem and the drive requires service. It is not a software problem.
Of course, the library could already have the maximum tapes it can hold. If this is the case then eject a tape from the library to make room for the tape you want to add.
I hope this helps.
Apr 17, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
Loading Media
Same problem with Backup Exec 10d and Superloader 3 LTO-3.
This is not my first problem with this Superloader. I think it is garbage and will likely be in the garbage very soon. Very expensive garbage unfortunately.
Mar 05, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
ATL Superloader with LTO2 drive
The LTO family drives all support a tape-related diagnostic spec called TapeAlert, and if you use a software product that decodes it and can dump out all of the settings related to firmware, error logs, etc ... then I have no doubt it will provide root cause. Check out http://www.santools.com/smart/unix/manual (the code is also ported to windows. There are links for TapeAlert reporting) Or go to http://www.tapealert.org for info on the spec.
Feb 08, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
How to compress file in Veritas exec 10
Make sure that your tape drive is using Symantec drivers. to do this follow these steps.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 31, 2007 | Veritas Backup Exec 10 for Windows Servers...
Quantum SuperLoader 3 LTO 2 Tape Drive Logo
2,438 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
