Question about JVC KD-NX5000 Car Video Player
KD-NX5000 TIME PROBLEMS
Since I hooked up my XM Radio to the unit the time is hardly ever right on this unit. I have to go into the settings change the timezone and than switch it back to the right timezone to get it calibrated. What did I do wrong??
Update your firmware at http://www.jvc-victor.co.jp/english/car/support/navi/nx5000_us/download_soft.html
This did the trick for me. Good luck...M
Posted on Sep 10, 2009
How do I reset the time on my JVC KD-R200 CD RECEIVER/ WMA MP3 PLAYER?
I am not sure about the reset. You can change time. Press and hold the SEL button. When the menu appears, if pressing left/right button doesn't select clock, try turn the volume to select and press right/left to set. Let me know it works.
Feb 09, 2015 | JVC KD-R200 Car CD/ MP3 Player
How can I get our 2011 Suzuki Kizashi to accept a USB cable to enable our portable XM radio unit to work? It currently states: "Not Supported" each time a usb is hooked up to the portable XM unit. (On
I believe the USB socket your Subaru is only a charging port and does not really hook to the radio. This would require more than I know how to do, unless you can enable bluetooth on the car and your XM will work that way.
Dec 12, 2014 | 2011 Suzuki Kizashi
XM radio keeps going out
Sounds like an antenna short. Check the routing of the antenna, or better yet, just purchase a new antenna.
Jan 13, 2014 | GMC Cars & Trucks
My KD-NX5000 has suddenly stopped playing all audio sources. CD's or DVD's start up and the timer shows that CD is playing but there's just no sound. The sat nav works as it should. Haven't...
Did you ever get this fixed? I'm kind of having the same problem, my radio works but nothing else is. I can hear music on the radio but when I switch to cd or bt (iPhone) ... I hear nothing thought (cd) it recognizes discs and I can see them play but no sound. It played before till one day it stopped. I don't know what changed or was set differently.
Jul 08, 2011 | JVC KD-NX5000 Car Video Player
Trying to hook up a AMP
What I did to manualy turn on and off my amp is I put a wire hooked to the fuse followed by a switch and then from the switch ran it straight to the amp. Make sure that the wire plugged into the fuse is the on the fuse for the radio and that it is live only while key is turned on. I have this set up for police reason. They do not like loud music where I live. I have never had a problem with this set up. RADIO FUSE-------SWITCH----------------AMP
Mar 03, 2009 | JVC KD-PDR30 Car CD/ MP3 Player
Time on radio
usually you would turn off the unit and hold the menu button for a fre seconds that will bring up a whole new set of options just scan through them and u should see adjust clock
Nov 18, 2008 | JVC KD-G200 CD Player
Getting CDs to play where they left off
Does you radio keep the correct time? If it doesn't then the problems are related. You don't have you memory wire hooked up right. If your radio does keep the right time after being turned off then you just might have a model of radio that does not do what you want it to do and the only solution to that is to get another radio. Good luck.
Jul 24, 2008 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Jul 08, 2008 | JVC KD-NX5000 Car Video Player
Xm radio
it might be the signal is out of range gotta love xm signals once detects the signal things should go back to norm
find xm antenna try to follow back to unit see if it just came loose from bumping it
a good reset way is disconnect from power let set for a minute or 2 and then plug back in
radio id should be xm compliant the sterio your using to push the sound you need that id
May 06, 2008 | Car Audio & Video
07 Armada
You will need to ask the dealer to replace the display again I'm afraid. I had a friend that had a similar problem with their Nissan. They had problems with display and the CD 4 times. If you try and do it yourself, that will void the warranty. Good luck
Dec 20, 2007 | Audio Players & Recorders
JVC KD-NX5000 Car Video Player Logo
118 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
