Question about Kenmore Washing Machines
My kenmore top loader won't spin,agitate or pump.
Whenever it should spin,agitate, or pump the motor runs and a ratchiting sound is heard but no action occurs. timer runs ,water turns on and off but no movement.
  • 22 Answers
Motor or carbon brushes gone
Posted on Nov 13, 2008
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
41 people viewed this question
Sal De
 Brian Main
Brian Main
