Question about Garden
I can't find an oil drain plug on a honda 5.5hp engine.gvc 160.
I have a Generac power washer, with a honda gvc 160 engine and can't find the oil drain plug. Can you help?
  • sspagina Nov 18, 2008
    Thanks stug_57u.
  • 99 Answers
The engine drain plug is on the main (square) base part of the cylinder block. I think it is 10mm. There is a compression washer to seal it aswell so it might need a bit of extra pressure to start it undoing. This should drain your block almost completely.
For diagrams go here, you will need the engine serial number and prefix.
For manuals go here,
Posted on Nov 14, 2008
Where is oil drain plug on troy-built waterpressure Honda GVC 190?
some small engines do not have a drain plug it may be at the bottom of the engine under neath where you can access it with a socket or hex key
or if none there , empty the fuel tank and pour the oil back out the filler tube
normally there is be around a pint (300 mls )
it may be a pain so check around underneath for the plug first
it is the same engine as used on lawn motors but with a different crankshaft to fit the pressure pump
Nov 08, 2015 | Garden
Grade of oil for honda gvc powerwasher
30 weight high detergent evry fifty hours due to the fact that it has a plastic camshaft
Dec 05, 2013 | Honda Garden
What of oil to change on the 2700 PSI Brigg & Stratton enigine? On a "Generac pressure washer" and also what type of oil and how to change the oil on the pressure washer pump.
id your engine model and consult the briggs site........
the oil in the pump is filled during assembly so it doesn't have a nice pair of fill and drain plugs
briggs :
Jun 25, 2013 | Garden
I have a black max gvc 160 cc engine and the valves are sticking need help on how to fix it
Without disassembly, you could try some crankcase additive and fuel system treatment. One product in the same container can do both. Go to the auto parts store and purshase a bottle of Sea Foam Fuel System Cleaner. It is for automotive use and your Honda qualifies. Add a proportionate amount to the gas tank (an ounce or so) and add a small amount to the engine oil. An ounce or so would be plenty. Run the engine just at idle awhile and give the chemicals a chance to work. It will clean up the carburetor and most likely the valves. You may want to drain a couple ounces of oil from the engine to make room for the Sea Foam. Overfilling the crankcase is bad for the engine. If this doesn't resolve the problem, disassembly and internal parts cleaning would be required; but it probably won't
You will need to do an oil change after adding the Sea Foam to the engine and running it as it will become dirty.
Jun 16, 2011 | Husqvarna 160 CC Honda OHC Engine 21 in
Have a honda gvc 160 power washer. It works ok for a while then loses all pressure. It seems as though when it is not running and the water is attached there is not as much water coming through. Is there a...
Sounds like the machine is not getting enough water.
Please check your water pressure to the machine and also the water inlet filter in case its a little dirty.
Jun 16, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 | Garden
Honda gvc 160 not starting. cleaned the ventui & plug
Check the fuel.
Drain some of the fuel into a white contain...I use a paint can lid. If it yellow to orange in color it's bad. You can pour the fuel into your car to get rid of it. A car has electronics that will compensate for poor fuel quality, small engines don't.
Check spark.
Remove the spark plug and reinstall the wire. Lay plug on the engine block where it can contact it. Pull over the engine. You should see spark. If not change the plug. If still no, I give you further instructions.
Mar 31, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
I cannot get the gas powered honda gvc 160 press wash to start
Pull float bowel and check carb may need to clean it. Drain any water from tank through fuel line.
Mar 18, 2009 | Honda 8 HP Engine
Garden Logo
1,786 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
