Question about Sony Cyber-Shot DSC-P52 Digital Camera
Lens cover opens only partially
When I turn on the camera, the lens cover opens only partially, and the message appears "turn power off and then on again", which I do, but to no avail. I also hear a whirring sound.
  • 3 more comments
  • cgsignorarch Nov 14, 2008
    I'm having a problem with my Sony DSC-P52. The lens cover will neither open nor close. It is actually permanently in a partially-closed position whether the power is off or on. When I turn the power on, I hear a rapid signal and see the message "turn the power off and on again". I do this, but nothing happens.
    I tried canned air, but nothing happened. The problem doesn't seem to be related to particulate matter.
    Prior to the lens cover refusing to move (its present condition), it would open partially, accompanied by a whirring sound.
  • cgsignorarch Nov 15, 2008
    As per suggestion, I removed the batteries for 30 minutea and then replaced them. The lens cover still refused to move from its 3/4-closed position.
    Is there some kind of miniature fuse related to the lens-cover motor drive that may have blown?
  • cgsignorarch Nov 16, 2008
    It does not appear that a speck of dirt is the problem. The lens cover moves freely when I nudge it with my finger. But it always pops back to the partially-open position. The cover motor does not appear to be working. It is not responding when I turn the camera on.
  • cgsignorarch Nov 22, 2008
    None of you "experts" seem to be getting this. The lens cover motor is not operating. The lens cover itself is permanently open at about i/4 of its normal full aperature. When the problem originally presented itself, I could hear the lens-cover motor whirring and the cover would open and close erratically. Now the cover just stays at the 1/4-open position and there is no sound of the motor trying to operate. I can of course move the two leaves of the lens cover with my fingers, but when released, they pop back to the same position mentioned above.
  • 10,594 Answers
To resolve lens cover problem in your Sony DSC-P52 camera, you need to replace Front cabinet Assembly because lens cover is mounted in it and not available as individual part. Below is exploded view of your camera.
You can order Front Cabinet under following part number...
X-3953-322-1 CABINET (FRONT) ASSY
Above said part is available in Part Store.
Need further info, please let me know.
Posted on Nov 22, 2008
  • 849 Answers
Two possibilities are there, either the battery gone week or the gear stucked. check them.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to clean the lens gear maybe dirt stuck on iy
  • ronald suboc
    ronald suboc Nov 22, 2008
    hi!!!
    try to clean the lens gear maybe dirt stuck on it
    Guru:
  • 97 Answers
Hello, this problem is normally caused by dirt particles. It is recommended that you put it off and take out batteries before cleaning and wait a while before powering on. If cleaning does not work, then you could try new batteries.
If these does not work, then the device would have to be opened which will require a technician's helping hand. Have fun and Thanks for using fixya.
Posted on Nov 16, 2008
    Genius:
  • 1,011 Answers
Sir,
open the lense manually before turning the camera on it works...Try to reset the camera if it is not worked call Sony at 1-800-222-7669.
thanks
good luck
    Sergeant:
    Champion:
  • 347 Answers
Hello cgsignorarch,
Your camera has a gear stucked.
When you turn it on, the lense has to come out. Inside of the camera there are gears witch make this possible (also when you zoom in and out).
If your lense do not come out what probbaly happend is that a gear got stuck or out of place. You can try to hit is gently untill the gear gets free of untill the pin"grabes" back the gear.
Try to turn it on several times tapping it. If that dosent work, you will have to open it up to fix the gear or take it to a sony repair shop where they will quickly solve your problem.
Good luck,
Dahaka
    Brigadier General:
  • 6,966 Answers
Offhand, the solution offered by IrishDruid would come to mind. Alternately, you could also try checking the battery terminals. You may need to clean/scrape them and/or bend/stretch so as to provide more pressure to the battery contacts. In some instances, you could try Alkaline batteries and not rechargeable ones.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 15, 2008
    Guru:
  • 558 Answers
It is worth to try this out in case of Jamming:
Just tap gently the camera but firmly against the palm of your hand. It usually works :)
You could also try twisting the lens in a clockwise fashion little bit, until it can go no further.
Hope it work, also try to remove all dirt and dust with a Blower or Vaccum cleaner.
Have a good luck,
Scott
    President:
  • 2,712 Answers
Sounds old fashioned, but it works..Just tap the camera gently but firmly against the palm of your hand. It usually works :) You could also try twisting the lens in a clockwise fashion until it can go no further.
Should this fail, it would indicate a larger problem, either within the circuitry, or the gear mechanism, for which a service call will be required. You could try the "Repair Service" box at the right. Input your Zip code and get a list of repair centers in your area. Shop around for prices,a nd mention you were referred by Fixya. Who knows, you may just get a discount!
Cheers!
ID
Posted on Nov 14, 2008
    Genius:
  • 1,913 Answers
Put away your memory card then press power botton for 10 seconds then it reset.
then refix batry again.
thats alll
  • kishor khatri
    kishor khatri Nov 16, 2008
    change your batry inside it.it may be working some thing rong.
    Scholar:
  • 181 Answers
Just ON the camera the door will open half.at that time block the door with your hand.remove the battery from your another hand.then shut the door manually from you hand ---close ---open ---.
5 - 6 times.if it is working freely with your hand then again insert the battery and check.
if it not working properly manually then check out something is really blocking the door to open .as if the gears behind the doors which help the door to move freely gets stuck due to dust collected in between them and this happens.
also change the battery and check sometimes this really helps in such problems.
also tap the sides of the camera slowly not very hard but continuously for 2 minutes solves this problem for many persons getting such problem.
  • Sony Master
  • 19,396 Answers
It is stuck because of dirt, dust, or because some part is slightly deformed or stuck.
Try gently helping the cover with your fingernail while you turn the camera on.
Be very careful, as there is always risk to damage the cover mechanism doing this DIY operation.
The safer alternative is taking the camera to a camera shop for repairs.
  • Sony Master
  • 6,487 Answers
Try first to remove the bettery of the camera for about 30 minutes then after that put it back in and check if you still have the same problem....
  • 1,879 Answers
Even a small particle can jam the lens. Try canned air first.
  • monk3ybidzness
    monk3ybidzness Nov 14, 2008
    Dirt jamming the lens is eliminated, now we go inside to check the lens retraction gears. Got tools ? or opt for service. It's your option.
  • monk3ybidzness
    monk3ybidzness Nov 15, 2008
    There's no fuse controlling the lens.
  • Sony Master
  • 13,433 Answers
You can try pressing the sides of the lens cover to see if it snaps open.
if that doesn't help you will need to get it repaired, if you got warranty, take advantage of that if not.
You can get a free repair estimate from advance camera
www.advancecamera.com/repair
When camera is turned on the lens opens and closes several times and then an error message appears: "Turn the power off and on again." When this is done, the camera does the same thing - lens opens and...
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Oct 20, 2010 | Sony Battery (844986068551) for CyberShot...
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Is it model with automatic cover of lens, like the DSC-T3 has? Problem is probably with lens cover. Try to move it (or help while it is trying to open/close) by your finger. It does sometimes if it is dirty (inside). I gues because you did not write the model name and number and on the picture is DSC-T1, but it has only 5.Mpix. If you have model with telescopic lens it is probably damaged gears of lens.
Sep 17, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Message turn power off and on again
your lens may be jamed thats why it tells you to turn off then on its tring to cycle the lens so i would check that first! good luck!
Sep 02, 2009 | Sony Cyber-shot DSC-M2 Digital Camera
My Sony Cyper-shot 7.2 digital camera - the lens will not open all the way, it makes noises when I turn it on like it's stuck and it says Access and then to turn the power off and on again. Nothing is...
Hi, The message "Turn off the power and on again" appears when the lens block assembly start malfunctioning, Therefore you have to replace the lens block assembly. Thanks for using fixya.
Jun 08, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Keep getting ERR99 when i take my first shot after switching on.
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Jan 23, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Camera powers up but lens cover fails to open
It could be some grit or sand causing the lens cover to not open, so the camera won't initialize. Try cutting a slip of paper narrow enough to slide between the lens opening frame and the lens cover. Move it in and out to clear any grit that might cause the spring-loaded cover to bind. Good luck !
Dec 14, 2006 | Sony Cyber-Shot DSC-P41 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
173 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
