Question about Sony Playstation 3 (PS3) Console
Hard disk corrupted
Everytime i turn on my game my system says hard disk corrupted how do i solve the problem?
  • Anonymous Nov 13, 2008
    my game will not stay on without freezing up on me. I tried a disk cleaner but doesnt work
  • masonscott Jan 17, 2009
    Everytime my son turns on his Playstation 3 the following message appears : The hard disk's file system is corrupted and will be restored 'ok'. He then press x for 'ok' then the following message appears : Restoring Do Not Turn Off... The message just then appears again and will never restore to enable my son to play..
Hi my ps3 did this in 08 i phoned up sony and as long as your ps3 is in warranty they will replace it
Posted on Jan 26, 2009
  • 344 Answers
Replace the hard drive.
Posted on Nov 13, 2008
Hard disk file system corrupt
Bad sector or MBR on Hard drive needs replacing
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Jun 03, 2008 | Sony Playstation 3 (PS3) Console
Hard disk corrupted
vlynch2819
If you are getting the corrupted drive message on your Playstation 3 this means you have corrupted data on your hard drive. The link below will help you fix the problem with the corrupted data. Note if you still have trouble then you will need to replace the hard drive as there is something wrong with it.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or question
Issken
http://www.fixya.com/users/issken
Nov 01, 2009 | Sony Playstation 3 (PS3) Console
Hard Disk is corrupted, would rather not reformat.
This is to do a factory hard reset on PS 3 all files and systems settings will be deleted and restored back to factory this should hopefully solve your hard drive a problem. depending on the system reformat clould take 3 1/2 hours do a full format as to clear
Faulty memory
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset)
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
Games freeze, no red lights
There are really only 2 options when looking at this type of error. It is either:
1. A bad Disk
2. An internal problem with the system
A bad disk (or multiple disks) will occur when they become scratched, dirty, or destroyed. The best option here is to clean the disks with a non-abrasive cleaner and hope that it solves the problem. A good test is to try a brand new disk to see if the problem goes away.
An internal problem is very hard to nail down. Freezing can be caused by a number of factors but it is almost always associated with an overheating situation. It is important to make sure that the XBOX has plenty of room and ventilation around it. In fact, the worst thing that a user can do is to place the console inside an entertainment center nook and close the door. It is recommended that the console sit outside of the entrainment center and away from heat sources. There are a number of add on components that you could buy to increase the airflow into the console as well.
If this is an XBOX 360, also consider that the hard drive may be going bad. The best way to test this is to get your hands on another hard drive that you know works and test it in your console. If the problem resolves then the issue is related to the hard drive.
Apr 21, 2009 | Microsoft Xbox 360 Console
Question about the hard disk
Your hard drive has been corrupted. There is an easy fix that will not void any waranties (If you have them). Just buy a new hard drive (Mine is a 500 GB Samsung for $125). Then lookup instructions on how to replace it on the Sony website. It is a very simple process.
Hope this solved the problem,
Mike P
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have...
you already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Dec 21, 2008 | Video Game Consoles & Games
by a new hard disk it is easy. The only thing is that you will LOSE  EVEYTHING THAT YOU HAVE ON THERE! you can find a cheap one for like 80 bucks I have a 160 gig in now and i paid 89.50 email me if you have questions baldwinkk@gmail.com
May 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
