Question about Cuisinart BFP-703 Blender
Attaching top container to bottom tub.
I have had Cuisinart for years but have not used it in some time and have forgotten the proper procedure to connect the top tub to the bottom tub now.
  • 8,596 Answers
Place food processor attachment on base
Put work bowl on gear collar with left slot just to the left of the tab on left side, slide until tabs click
Place work bowl lid on top of workbowl with tabs slightly to left of work bowl handle - slide into place until it clicks
Posted on Dec 12, 2008
Attachment stuck
try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
May 10, 2014 | Cuisinart CSB-77 SmartStick Blender
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Cuisinart DFP-14 Series does not start
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor plugged in and turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. For the DFP-14, remember: handle faces front, feed tube faces back, and metal element on back of pusher faces back of processor. Connect the pieces separately - if you try to put the work bowl on with the lid and pusher already attached, it will not always lock properly. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 17, 2008 | Blenders
Cuisinart CBT-500 blender won't work
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Apr 13, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart bc56 blender
how to get the base off the glass container. turn in what directionss it seems stuck
Feb 27, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Replace the blade driver clutch on a Cuisinart CBT-500
I had this same problem. It was solved but let me tell you it was a nightmare and we were almost sure the blender would be destroyed at least 3 times during the ordeal.
Here's a hint: the thread is on opposite to a normal screw thread so that it gets tighter as the blender spins.
Steps:
1. Take the base off the blender and pop out the motor.
2. Turn over the motor and remove the round rubber part at the bottom. You will see a flathead screw. This is where you grip the shaft that the cursed brass coupler thread is attached to.
3. Find someone else to help and also a large strong flathead screwdriver.
4. With a friend holding a screwdriver in place at the bottom, grip the top brass thread with pliers (or better yet a pipe wrench) and twist it the opposite way you normally would.
5. Become extremely frustrated by the fact that the screw thread is made of cheap metal and strips instantly and that the brass thread is also cheaply made and rips right through your pliers / wrench.
6. Find a hack saw and a hammer.
7. Cut the brass thread off with the hack saw. Hammer the stubborn remaining pieces of it off with a screwdriver. Be prepared to cut off half of the shaft.
8. Eventually you should have hammered / sawed the brass thread off. If the shaft and motor are still intact, you can now screw the new coupler on (remember - its backwards). We had only about half of the shaft thread left and it still worked ok. Make sure to do this after you put the motor back in place with the shaft poking through the top of the case. Don't worry too much about how tight it is. As I mentioned its on backwards to tighten the coupler during normal use.
9. Replace the casing and screws, don't forget that rubber thing at the bottom.
10. Curse Cuisinart and make a drink, you deserve it.
Sep 21, 2007 | Cuisinart CBT-500 SmartPower Premier Work...
Cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Blade turns with difficulty
Check the blade assembly it may be worn out.
Mar 27, 2007 | Vitamix 5000 Work Top Blender
Cuisinart BFP-703 Blender Logo
215 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
