Question about GE JE1860 Microwave Oven
Microwave not working
My ge je1860 microwave started making a buzzing/thumping noise along with flashing yellow color behind a side panel inside the unit when in use. When you stop the microwave it quits
  • 2 more comments
  • sdesros Nov 16, 2008
    the answer did not work for the problem, the problem has to do with the sensor module, it is sparking and appears to have burnt something behind the ceramic cover
  • Anonymous Dec 23, 2008
    I have the same problem just started today. I read elswhere that it could be food and oils that have built up on the ceramic wave shield on the side and to clean it real good or replace it.
    Let me know if you have solved your problem and what you did.
  • dmhel521 Dec 28, 2008
    mine does the same thing, it won't cook popcorn at all without sparking, and then randomly when cooking other things
  • Kent Norris Mar 15, 2009
    Microwave starts sparking/flashing whenever cooking popcorn, and then randomly and sporadically when cooking other foods. Do not notice the problem at all when using defrost.
    Scholar:
  • 181 Answers
Faulty relay or solder joint on the power module, but a bad door switch is most common.
Posted on Nov 13, 2008
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
Microwave JE 1860 has been making a loud noise for several months. Today it quit. Nothing works. No light. Turntable does not turn. Nothing on the display ... not even the clock. The unit was purchased...
Unless your personally attatched to this oven I would recomend you start shopping for a new one. Take the cover off and look for any fuses inside the front door area or on the control board, If they are bad replace them if none there then get a new one as they are more expensive to repair than replace. Most likely your magnatron shorted out and took the circuit with it, but check your house fuse as well on that circuit to be safe. A magnatron runs around 90bucks part only.
Jul 01, 2011 | GE JE1860 Microwave Oven
My microwave is making a loud buzzing sound. Inside the microwave, on the upper right side, is a square area with holes in it. It sounds like the buzzing is coming from behind those holes. Also, after...
THe buzzing noise is most likely coming from the magneton. The magnetron is the main component of the unit (it generates the microwaves). Replaceing it can be very expensive. You may be better off getting a new oven. Prices for new microwave ovens have dropped significantly.
Jun 12, 2011 | Microwave Ovens
Wont turn on and no display showing no light on inside. Its plugged in and circut breaker has been checked. 8 Years old
It may be either the line fuse or the magnetron's thermostat.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting, testing, and locating components.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Aug 18, 2010 | GE JE1860 Microwave Oven
I have a GE JE 1860. Someone ran the microwave for 15 minutes with nothing in it. Now it doesn't work at all , no power, no lights, nothing. Is there a fuse that may have gotten burned out? Is this...
There is a fuse and cavity thermal fuses as well as one on the magnatron that is supposed to reset itself.. The fuse is behind the control panel and the cavity fuses will require removal of the cabinet. Did you check for power at the plug?
Eric
Jun 20, 2009 | GE JE1860 Microwave Oven
Buzzing noise.microwave not working
That's almost always a defective filter capacitor on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 19, 2009 | GE JVM1860 Microwave Oven
GE Microwave Model # JE1860: Unit does not heat. The timer counts down, but the oven does not heat.
When you hit Start to cook, do the inside light, cooling fan, and turntable come on?
Any unusual noises? Is it louder or quieter than usual?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Nov 27, 2008 | Microwave Ovens
GE JE1860 Microwave Oven Logo
293 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
