Question about Nintendo Wii Console
Wii cd rom will not work after i installed the wiikey2 chip. i tested the solder points and aperar to be no shorts to othe chips. The wikey chip turns on with red led power light, and then blue led turns on on chip. the blue cd rom led turns on on wii power up, but when you try to insert cd, the cd will not even get loaded int the machine. Any sugestions, the connectors apear to be attached to the cd rom
Temp solution, was to leave all wires solderd in place to confirm that there were no shorts , and to remove the Wiikey2 chip. The chipset on the wii is D2E.
I may have a bad chip or the wiring diagram is wrong....
I'll keep you posted when full modification is done.
Posted on Nov 14, 2008
Needs to removed bios password on C55-a5249
I just discoverd this and i will brag on being the first. This is what you do. First remove battery and cmos battery. Remove one ram chip (Lower) and leave upper ram chip in.Use whatever you like to jump these solder points. While shorting solder points with power cord plugged in, turn on power and check. Worked for me first try. I AM THE KING!
Oct 31, 2013 | Toshiba Satellite C55-a5249 15.6" Led...
Tip
"double vision" caused by bad solder points on convergence chips (check before...
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able to smack the side of the tv or tap the heat sink for the chips and it corrects the problem than chances are the chips are fine butone or more of the solder points are bad. When I looked at the joints for the chips I noticed hairline cracks around the base of the joint. Re-soldering the joints for the convergence chips solved my problem.
on Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Computer beeping and won't start up
Dear,
There is a full code list that relates with the problems. You can justify yourself that which type of beeps, you are facing. I am going to write down the codes for you.
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Hope, now it will be quite easy for your do check and troubleshoot the issue.
best of luck, ask further if required.
Mar 08, 2012 | Computers & Internet
Fujitsu amilo simens Pi1536 and Pi1556 bios password chip locatio
Hi ,
Replacing the existing BIOS chip with a new one you can buy from your specialized electronic shop or your computer supplier. It's a quick operation if the chip is inserted on a base and not soldered to the motherboard, otherwise you'll have to unsolder it and then put the new one. In this case would be more convenient to solder a base on which you'll then plug the new chip, in the eventuality that you'll have to change it again. If you can't find the BIOS chip specifically made for your motherboard, you should buy one of the same type (probably one of the ones shown above) and look in your motherboard manufacturer's website to see if there's the BIOS image to download. Then you should copy that image on the chip you bought with an EPROM programmer.
Important
Whether is the method you use, when you flash the BIOS not only the password, but also all the other configuration data will be reset to the factory defaults, so when you are booting for the first time after a BIOS flash, you should enter the CMOS configuration menu (as explained before) and fix up some things.
Also, when you boot Windows, it may happen that it finds some new device, because of the new configuration of the BIOS, in this case you'll probably need the Windows installation CD because Windows may ask you for some external files. If Windows doesn't see the CD-ROM try to eject and re-insert the CD-ROM again. If Windows can't find the CD-ROM drive and you set it properly from the BIOS config, just reboot with the reset key, and in the next run Windows should find it. However most files needed by the system while installing new hardware could also be found in C:WINDOWS, C:WINDOWSSYSTEM, or C:WINDOWSINF .
ERNZ
Jan 16, 2010 | Fujitsu AMILO PC Laptops
My acer aspire was not working, I went ahead and put in a new hard drive. Problem is now I need an operating system. I have no back up or program CD's. A friend gave me a windows 2000 pro, when I try to...
I am guessing your southbridge chip de-soldered itself from the severe heat it causes which is not ventilated. Very common problem with aspire laptops, also keyboards, dispays, and cd-rom's are common to quit due to the southbridge chip. warranty fix will do nothing but buy more time. You may be able to put something on the chip to put pressure on it, worked for some, not me.
Aug 04, 2009 | Computers & Internet
How to modify ps2
The chip is nt pirated. The thing is it is a small chip that has to be installed with the main chip on motherboard where code has been installed. After installing chip, main chip can't recognize original code, thus copied PS2 media works on MOD Chip.The chip comes with many little wires. You can't install that. Go to a expert. It will take an hour to install. Feel free to ask any problem related PS2.
Thank you,KABIDkms_pb@yahoo.com
May 28, 2009 | Sony PlayStation 2 Slimline Console
How to boot from cd if i cant change the boot sequence.
click F8 when ur computer starts....then 3-4 options occure like BOOT FROM IDE DEVICE, BOOT FROM APTMA CD-Rom etc... select ur cd rom device to boot from cd...
Mar 10, 2009 | Dell Latitude 100L Notebook
Bios problem
Standard Original IBM POST Error Codes1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
PCHELL.COM Newsletter
If you would have read my E-book on Internet Security, you may not have ended up in PCHELL. Join the PCHELL.com mailing list and receive your free E-book now.
Name:
Email:
Tools for Removing Spyware, Adware, and Malware
PC HELL
Other Pages
Spyware/Adware Removal Help
MSBlast.exe Worm Removal
Welchia (Dllhost.exe and SVCHost.exe) Worm Removal
Uninstall McAfee Instructions
Uninstall Norton Instructions
Uninstall Avast Instructions
Uninstall AVG Instructions
Uninstall Antivir Instructions
How to Manually Run the Microsoft Malicious Software Removal Tool
Bloodhound.Exploit.6 Virus Removal
MyDoom Virus Removal
MiMail.C Virus Removal
Swen Worm Virus Removal
SoBig.F Worm Removal
Dumaru Virus Removal
BugBear.B Worm Removal
SoBig.E Worm Removal
Pop Up Ad Removal Info
KAK Worm Removal
MiMail.A Worm Removal
W95.MTX Virus Removal
Snow White Virus Removal
BadTrans Trojan Removal
Wininit Virus (Bymer Trojan)
Happy99 Worm Removal
VBS Netlog Worm Removal
Pretty Park Worm Removal
Sasser Worm Virus Removal
Backdoor SDBot.H Trojan Removal
VBS.Loveletter Help
Computer Security Information
Back Orifice Information
PC HELL Main Page
IBM POST Diagnostic Code Descriptions
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Color/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Color/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
 1 Short Beep One beep is good! Everything is ok, that is if you see things on the screen. If you don't see anything, check your monitor and video card first. Is everything connected? If they seem fine, your motherboard has some bad chips on it. First reset the SIMM's and reboot. If it does the same thing, one of the memory chips on the motherboard are bad, and you most likely need to get another motherboard since these chips are soldered on.
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above.
4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
5 Short Beeps Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
6 Short Beeps The chip on your motherboard that controls your keyboard (A20 gate) isn't working. First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
7 Short Beeps Your CPU broke overnight. Its no good. Either replace the CPU, or buy another motherboard.
8 Short Beeps Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
9 Short Beeps Your BIOS is bad. Reseat or Replace the BIOS.
10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard.
11 Short Beeps Your problem is in the Cache Memory chips on the motherboard. Reseat or Replace these chips.
1 Long, 3 Short Beeps You've probably just added memory to the motherboard since this is a conventional or extended memory failure. Generally this is caused by a memory chip that is not seated properly. Reseat the memory chips.
1 Long, 8 Short Beeps Display / retrace test failed. Reseat the video card.
Oct 18, 2008 | Computers & Internet
WII shuts down when power or eject is pressed
Depending on the chip and who installed it, it is probably shorting out something in your system. Even if the system was working before, it might have shifted or come loose. If it is only shorting your power switch then it would just be a simple adjustment of the chip. However, the chip could have shorted out your main board and when the system powers on, it detects the short and shuts itself off as a fail-safe. Removing the chip *might* fix it if it didn't totally fry the system.
Aug 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
244 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
