Question about Canon L IS WP (10x42) Binocular
Black particles in binoculars
I have black particles that can be seen when I look through my binoculars. These spots are not outside of either lens. The brand name is Bower. Any advise?
Thank you
  • Dawn Gifford
    Dawn Gifford Nov 17, 2008
    We fixed it ourselves......
  • 112 Answers
If you black spots then they are more than likely on the eyepiece field lense. dont know what kind of bino you have, if its cheap then probably not worth repair. this problem was usually found in the old zeiss. they used a black wax to seal them, and they are worth repair because they last
Posted on Nov 30, 2008
Take it to the doctor then write me and tell me what they say
Posted on Nov 14, 2008
Mark on Pictures
It could be some dust particle on the lens to a faulty sensor. Check the lens if you can spot any abnormality on it and if not, please get it serviced.
Nov 03, 2013 | Canon PowerShot A1300 16 Megapixel Digital...
How can I fix the sticky black surface of the outside of my binoculars?
Try cotton pads (makeup removal type) and Isopropyl alcohol. it works about 75% of the time. Cotton balls can leave a lot of fibers.
Jul 29, 2013 | Bushnell Powerview Binoculars 8X25 Compact...
Eye piece lens detached
Find best compact bird watching binoculars for sale, best compact spotting scope that let you get closer to nature. Welcome to
Aug 20, 2012 | Minolta Optics
Dark spots on appears on nokia n85 8 mp camera
The dark spots is seen in your camera because inside the camera (LENS) some dust/particles may stick.You can check it out by removing the camera and clean all the lens and the housing (cover) which is seen straight to the camera(lens).If not solve the last thing is to change the CAMERA (lens).Good luck
Feb 20, 2012 | Nokia Cell Phones
All of a sudden, i see a dark black spot in the camera lens / picture... the spot appears on all the pictures. Please suggest fix.
Hiyour unit has dust a particle in front of image sensor surface (ccd unit). you or someone else must had used to clean front of lens or side of barrel caused the particle got in. In order to remove that it need some sort of complete disassemble require. I recommend to bring your local repair shop. They would charge around $35 to 115 depend on what they want to charge.
Jun 03, 2011 | Canon PowerShot SX100 IS Digital Camera
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Sony DSCW50 Black spots on image
Sony will replace lens assembly.
I'm not sure about qualified local camera tech will apart lens assembly to clean it.
Mar 14, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Zeiss jena
Zeiss lensis usuali have on lens logo like "Z" I sopouse that small mark you see is that
Feb 27, 2008 | Steiner Genuine G.I. 7 x 50 Binoculrs with...
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Canon L IS WP (10x42) Binocular Logo
214 people viewed this question
Top Canon Optics Experts
old marine
old marine
Are you a Canon Optic Expert? Answer questions, earn points and help others
