Question about Canon PIXMA MP150 All-In-One InkJet Printer
Jamming Every time i try to print a screen pops up telling me that there is jammed paper in it, even if there is no paper in the printer at all, and on the display screen it keeps flashing E 3 E (like an E flipping back and forth). The printer was jammed but i took the jammed paper out and nothing has changed. how can i fix this?
  • 47 Answers
Hi Scott, My experience is if there was a jam and it still says it's jammed after clearing the paper you missed some. Even if the sheet that caused the last jam didn't tear it may have moved a torn piece of paper that was in there from before. Check again, really well for small pieces of paper stuck somewhere. Hope that helps. If not let me know and I'll see what else we can do. El Duderino
Posted on Nov 17, 2006
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
Paper won't load. and Stops printing before it can start.
Try turning the paper around. Some times the corners of the paper get slightly bent and the paper wont load.If turning the paper around does not work, switch your paper. Hope this helps.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
Paper Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Paper jam
give this a shot
alternative :
Jul 08, 2008 | Brother Multi-Function Center MFC-665CW...
Paper Jam
Remove all the paper from the paper tray so that nothing gets sucked up in there while you're working. Hit the cancel button a few times until the screen clears itself and goes back to the "Print", "Copy", "Scan" option screen.
On your computer, if the printer option screen is up (depending on what kind of computer you have, a small screen might pop up to tell you the print progress), hit cancel or clear on any of the lines that say "Paper jam", if there are any.
The next time you print something, only put as many pieces of paper in the feed as you need to print. This should eliminate a lot of the chance of actually getting a paper jam.
Please respond again if this didn't help. I'm not sitting in front of my own computer right now, so I might not be following the same steps that I usually take.
Feb 02, 2008 | HP Photosmart C4280 Aio Printer
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
205 people viewed this question
old marine
old marine
