Question about Freezers
Punctured the inside wall of the freezer - gas has escaped
Can I fix this hole and replace the lost nitrogen gas or am i going to have to get another fridge freezer???
  • jamesdawson Nov 14, 2008
    Thanks for the quick response. Unfortunately you have confirmed what i feared.
    Novelist:
  • 124 Answers
You're all done buddy. sorry to say i have never seen in 21 years of doing ac and ref work anyone that could weld aluminum saturated with oil . an airtight hermetic seal is mandatory, and with a hole punched its new unit time. sorry
Posted on Nov 14, 2008
How could i fix my ref i was able to puncture it? .. how could i fix it?
you cannot fix a punctured evaporator coil. The cost is not economical and the repair is unreliable. best consider another fridge.
Jun 20, 2014 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have poked a hole in my freezer unit while defrosting and the gas escaped. Can the hole be repaired and the gas replaced?
Yes it can, but you are going to need special equipment. Such as a vacuum pump to remove the air, Touch to repair the hole or replace the evaporator that you poked the hole in. Along with a set of gauges and refrigerant.
This is not a job for the average DIY'er and even as a pro I only repair sealed systems (leaks, compressor, etc..) if they are under warranty because it's a time consuming and costly job other wise.
If the refrigerator has any age on it then you may want to start shopping around for a new one.
Aug 02, 2011 | Danby Freezers
I punctured something in my freezer and it is hissing. Can I fix this
You can fix it. You would first need to find the leak and repair it. Then your would need to evacuate the air out of the sealed system to prevent ice blockage. Then you would need to slowly add gas to the system till it reaches a maximum of 5PSI no more. Then you oughta be good.
Jun 30, 2011 | Freezers
I need to run several 3/8" tubing out from inside
you should not drill any holes in the unit the cooling lines run throught he entire cabinet.why do you need to drill a hole in the unit?
Mar 19, 2011 | Frigidaire Freezers
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Sep 30, 2010 | Haier 4.5 cu. ft. / 127 liter Chest...
Brand new upright the back wall of freezer has a
i have filled polythene bags with paper scunched up inside.to fill any empy drawers this will stop all the cold air escaping and being replaced with warm damp air.....works for me.....
Feb 01, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not keeping foods frozen
If this freezer is running all of the time and only freezing the walls at the top inside it is a good chance there is deteriation in the piping in the walls eg (rusty pipes) letting the refridgerant escape (common fault) with chest freezers.If it is more than 7 years old it would be advisable to replace it as the repair would probably cost 3 quarters of replacement price.Hope this helps. Kind Regards.
Nov 27, 2009 | Woods 4.3 cu. ft. / 122 liter Chest...
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Punctured gas line/ uses R-12
not very easily. Most freezers have the evaporator and condenser inside the wall of the cabinet and you cannot access them. If the puncture is in the condenser you can put in an exterior condenser however the parts break down for your model does not offer this option (:
Apr 08, 2009 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Hole in the bottom of freezer
Short answer no. The only way to repair it would be to strip back to the pipe cut the broken section out and replace it. If the broken section is aluminium this is even harder to correct. The system would then need to be vacd and recharged. Bearing in mind the evaporator which you punctured is on the low side you have probably got oil contamination which could mean the compressor could fail in a relatively short space of time. All of which means you are probably looking at a new unit. You can get this confirmed by explaining the leak to a local fridge guy. In my opinion it would cost more to repair than to replace. Hope this is of some help. PS this happens a LOT and is normally a fatal wound.
Sep 11, 2007 | Freezers
Freezers Logo
896 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
