Question about Sharp (AN-XR10LP) Projector Lamp for XR10X
NO POWER TO UNIT...
I followed the instructions as given by one of your other "troubleshooters" by opening the projector and resetting the red push-in button. However, after approx 45 minutes of operation, it blacked out again. I have the unit mounted upside down approx 7" from the ceiling. When the unit had power failure #2, I reset the red button again and ran the projector for over 3 hours. This time I set it right side up on a small stand. No power failure has occurred. Would the ceiling mounting of the unit somehow be causing this failure? I have initiated action through my SquareTrade Warranty, but before I send it in it for repair, I will need to duplicate the problem as right now the unit is working fine. Other writers-in regarding the solution to this problem (opening the projector and resetting the red button) have not really explained why this shut-down occurred in the 1st place. If due to overheating, are the fans not operable or less efficient when hung upside down?
  • xmadmax Nov 14, 2008
    This problem pertains to the Sharp XR10-X Projector, not the lamp...
  • 2,237 Answers
Yes. it's warm up there. and it's suceptible to alot of dust and dirt. all of that will cause the projector to overheat frequently. also: if you've had to reset it that many times, it's wearing out, and you should replace the bimetal breaker (the little red button).
Posted on Aug 19, 2009
How do I reset...followed instructions but still will not turn on
Do any lights come on when you plug in the power cord? If the power and lamp lights both glow red, the problem may be in the "ballast" circuit. The projector will have to go to a service center.
Sep 26, 2010 | Sharp XV-Z2000 Multimedia Projector
SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
Jan 12, 2010 | Sharp XR-10X Multimedia Projector
XV-H37U projector. Red power light is on when
reset the lamp timer. it's usually hold menu button , down arrow, and enter, and press power. but it's an old projector and may be different.
Nov 29, 2009 | Sharp Office Equipment & Supplies
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
XR-10X/XR-10S - Can't find a way to open up the lid!
maybe your Sharp XR-10X are damage so you want to know what will you do??
Sep 17, 2009 | Sharp XR-10X Multimedia Projector
No power
there are six screws in the base and two in the back of the unit. After taking off the top I saw a red button on the front that was a little pushed out - I pushed it in and I got the led lights back :)
Jun 22, 2009 | Sharp XR-10X Multimedia Projector
Sharp XG-P25X - only white screen, no OSD, no response
It sounds like you tripped the tamper switch? Factory or authorized service center and reset via rs232 Sorry.
Apr 02, 2009 | Sharp Conference Series XG-P25X Multimedia...
How to reset the bulb timer for TOSHIBA TLP-XD2000
The booklet that comes with a new lamp specifies the following for the TLP XD2000. While holding down
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Mar 16, 2008 | BenQ MP610 Multimedia Projector
No power
No Power "Whatsoever"
I Followed all the instructions in aarrowgant post
when I got to the fuse I removed it and checked it with
my ohm meter, and guess what it was not blown!!!
I used a can of gas duster to blow out unit.
I reassembled the projector except for the top of case and
plunged it in "No Power" I disconnected The power
There is however a small thermal switch I Noticed mounted
on the front of the lamp housing only accessible with the case
top off, It has a small red plastic reset button on it. I dusted
this off and pushed it. pluged it back in and the power light came on followed by the projector powering up. I reinstalled the top and mounted projector back on ceiling. Working fine now 48 hrs.
This entire proceeure took me 2 1/2 hours and cost me nothing.
Good Luck,
cyberphx
Nov 05, 2007 | Sharp XR-10X Multimedia Projector
163 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
