As we give program to the machine. all usual LED light up for 2 seconds,than all LED switched off ,a hamming noise is hear from inside the machine .than the END LED start blinks for 3 times .
-   My lavamat fills with water and a couple of seconds later it drains, leaving the end light flashing three times. The only fuction that works is the spin.-   mdadv
The mechine doesn't drain the water and the end mode is blinking when i trun it on. when i...
(More)
The mechine doesn't drain the water and the end mode is blinking when i trun it on. when i disconnect the power terminals from the pump the end mode stop blinking and the mechine starts,drum spin etc.. i put a new pump but still the same problem , i checked to see that the controller give 220V to the pump power terminals and it does. it semms that whenever i put some load on the pump power terminals the mechine goes into end mode .
Hello, Our AEG Lavamat W1050 had a broken handle, I have bought a new one, but am unsure how the...
(More)
Hello, Our AEG Lavamat W1050 had a broken handle, I have bought a new one, but am unsure how the springs sit. Please can you send me a picture, or advise. Thank you
My machine did not tumble any more and the repair man replaced the brushes. It worked for 2 loads,...
(More)
My machine did not tumble any more and the repair man replaced the brushes. It worked for 2 loads, and now again, it does not engage. water fills up, however not turning , tumbling, spinning... where do I get a new cicuit board,, or a repair manual - not a user manual?
Hi, my Lawamat W1050 does not rinse or spin when I put the knob on the Cottons Linen ? I have...
(More)
Hi, my Lawamat W1050 does not rinse or spin when I put the knob on the Cottons Linen ? I have checked on other programs and it works just fine. The red END indicatior light flashes constantly when the program is finish... any ideas ?
